On other hand my iPad doesn't load feed (index.hu) if crossorigin.me is enabled. So it's site specific. Should I create a global setting for this var_RSS_CROSSORIGIN?robgeerts wrote:Well, if i remove it, it says it doenst allow me to open the site...madrian wrote: I already sent fix to this, default should be disabled. I think RSS feed doesn't need CORS proxy. +One more fix for sites with iframe protection (if it's detect, the parent window (dashticz) is redirected to the opened URL).
This occurs with the train info, traffic info and news sites....
I did add your sandbox fix to the latest version.
Re: Dashticz v2.0, custom positioning and multiple screens
robgeerts
- Domoticz version: 3.7067
Train (NS) is fixed now!wizjos wrote: Is it possible the ns has broken down
Traffic produces output, but train doesn't...Code: Select all
columns[7]['blocks'] = ['blocktitle_3_1','news','traffic','train']
robgeerts
No global setting i think, because its not that its needed with very site but for some sites (or not needed).madrian wrote:On other hand my iPad doesn't load feed (index.hu) if crossorigin.me is enabled. So it's site specific. Should I create a global setting for this var_RSS_CROSSORIGIN?robgeerts wrote:Well, if i remove it, it says it doenst allow me to open the site...madrian wrote: I already sent fix to this, default should be disabled. I think RSS feed doesn't need CORS proxy. +One more fix for sites with iframe protection (if it's detect, the parent window (dashticz) is redirected to the opened URL).
Maybe I have to remove it completely for news rss but if it returns errors, the news plugin will try again with crossorigin?
I think it is an acceptable solution. Or what I committed, it's clear to everyone:
But I think it's needed only for traffic/train info. I don't know these services.
//if RSS feed doesn't load try: $.ajax('https://crossorigin.me/'+newsfeed, {
$.ajax(newsfeed, { -
robgeerts
Accepted your merge-request, although, people have to add the crossorigin in config.js, not in news.js because within a next update it will get revertedmadrian wrote:I think it is an acceptable solution. Or what I committed, it's clear to everyone:
But I think it's needed only for traffic/train info. I don't know these services.Code: Select all
//if RSS feed doesn't load try: $.ajax('https://crossorigin.me/'+newsfeed, { $.ajax(newsfeed, {
So for example:
blocks['news_2'] = {}
blocks['news_2']['feed'] = 'https://crossorigin.me/http://feeds.feedburner.com/tweakers/nieuws';
Ahhh you are right. And what a nice solution!
- htilburgs
Updated wikimadrian wrote:Please add buttons.webcam to the wiki, it's missing.
Hardware:
Thank you.
I forgot to mention to you the new streamplayer.
Is there any other feature which is missing from the wiki? We must keep it updated, because things are changing so fast here.
- htilburgs
Please, if something is missing, let me know.
By the way, the streamplayer is already there
http://www.domoticz.com/wiki/Dashticz-v2#Radio_Plugin
Hardware:
- htilburgs
Rob, I've just pulled the latest version. Now the RSS / News feeds don't work anymore.
Something broken?
Something broken?
Hardware:
robgeerts
Yes, and thats something else you need to add to the wiki:
You have to put https://crossorigin.me/ before the newsfeed-url, like:
You only have to add it when news doesnt load..
Some news sites are giving errors otherwise..
- EdwinK
- Domoticz version: BETA
Wouldn't it be nice if there was a switch that goes off when there is a new version of the Dashboard.
robgeerts
CUSTOM.JS
In the latest version, there's a new file: js/custom.js
Here you can add your own functions.
Theres a predefined function wich will be called when the dashboard got all device informatie, name: afterGetDevices()
You can enter code inside this function wich you want to be called.
Of course, you can also use stuff like $(document).ready() etc.
- htilburgs
Rob, the Newsfeed remark is added to the wiki to.robgeerts wrote:CUSTOM.JS
Tomorow I'll look into the CUSTOM.JS and add this to the wiki. For today I'm checking out
Hardware:
pvm
- Domoticz version: 4.10538
-somehow double posted-
pvm
Is it possible to display the wind-chill temperature (or display both normal and wind-chill temperature in one block)?
I get this information from buienradar:
edit : typo fixed
- "Chill" : 1.5, (representing the windchill/'gevoels temperatuur')
- "Temp" : 4.4000000000000004, (representing the temperature)
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"Chill" : 1.5,
"CustomImage" : 0,
"Data" : "330.0;NNW;34;54;4.4;1.5",
"Description" : "",
"Direction" : 330.0,
"DirectionStr" : "NNW",
"Favorite" : 1,
"Gust" : "5.4",
"HardwareID" : 8,
"HardwareName" : "Buienradar",
"HardwareType" : "Buienradar.nl (Weather lookup)",
"HardwareTypeVal" : 94,
"HaveTimeout" : false,
"ID" : "00080006",
"LastUpdate" : "2017-04-17 22:33:13",
"Name" : "Buienradar - Wind",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Speed" : "3.4",
"SubType" : "TFA",
"Timers" : "false",
"Type" : "Wind",
"TypeImg" : "wind",
"Unit" : 6,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "48"
xtrememotion
Hello, I am really enjoying your dashboard, thank you for your hard work! I have found a bug, but have the solution. I haven't done anything with Gitlab, so I am posting here in my ignorance
On your main.js, lines 18 and 19 need to be switched in order to allow the sliders to work on touch screens. In my case I am using your dashboard on a raspberry pi 3 and using the 7" touch screen in Chrome. Without swapping the two lines below, I could not get Chrome to slide the sliders (however it did work in Iceweasel). According to the touchpunch documentation here: http://touchpunch.furf.com/ It has to come after the UI.
In main.js:
To:
In main.js:
$.ajax({url: 'vendor/jquery/touchpunch.js', async: false,dataType: "script"});
$.ajax({url: 'vendor/jquery/jquery-ui.js', async: false,dataType: "script"});
marcotrumpet
Hi, how can I send you the files?robgeerts wrote:I know:madrian wrote:I think the next "big" feature should be to swipe between screens. Clicking on the small icons is not very comfortable.
Could you send me the modifications?marcotrumpet wrote:Hi guys! I love this dashboard! My brother made me two excellent mod to this. My screens are now scrollable and now they adjust themselves to different device's screen. He also put swipe to change screen. Now, the problem is that I don't know absolutly nothing of this stuff and I don' know were changes are. If you are intrested to implement this feature in the official project I can sand you the files he modified. Let me know
I tried the last version of Dashticz and I notice something. In your version the dashboard doesn't fit different screen, it only squeeze content. If I found a way to send you my folder you can see what I mean for "element fit different screen". Sorry if I can't help so much but I didn't make changes to code by my self
marcotrumpet
EDIT:marcotrumpet wrote:Hi, how can I send you the files?robgeerts wrote:I know:madrian wrote:I think the next "big" feature should be to swipe between screens. Clicking on the small icons is not very comfortable.
there you go http://cnv.as/t9jc2
that's my dashboard with auto adjust screen, scroll through page and swipe to change screen instead litle dot at the bottom.
robgeerts
I tested with SlickCarousel yesterday and noticed that if you start swiping, and your finger is at the position of a switch, it switches that button so I've gotta prevent this before I publish this function. By the way, your link doesnt work.
