Would like a big clock either in standby-modus, maybe with some info..robgeerts wrote:Fixed in latest version!gjaa wrote:My doorcontact's state never change, it's always open
Blueone wrote: I also want to create an other stand-by few with a big clock etc, I can image that this is more a personal choice so I wan't to add it in the custom css. I'm a bit of newby is css en js world. Can I do something like this in the css to overide something when the standby class is available? s
- EdwinK
- Domoticz version: BETA
Re: Dashticz v2.0, custom positioning and multiple screens
pkrabben
- Domoticz version: 3.5877
Really nice.robgeerts wrote:Fixed in latest version!gjaa wrote:My doorcontact's state never change, it's always open
What about defining different columns/blocks for standby-mode?Blueone wrote: I also want to create an other stand-by few with a big clock etc, I can image that this is more a personal choice so I wan't to add it in the custom css. I'm a bit of newby is css en js world. Can I do something like this in the css to overide something when the standby class is available? s
Something like:
If people are interested in this, let me know, I will look into this!
robgeerts
- Domoticz version: 3.7067
In latest version, you can add the next var to config.js:Dropshot wrote: 4. The newsfeed scrolls trough the news items (which I really like!), but for me this scroll speed is just a bit too fast, I cant read everything before it scrolls again. Maybe it can scroll a bit less often?
var _SCROLL_NEWS_AFTER = 7000; //milliseconds, so 7000 is 7 seconds
robgeerts
DIFFERENT BLOCKS IN STANDBY MODE
Many people want a bigger clock or a slightly different screen in standby, now you can define different columns.
This way, you can use a big clock. Check out the example:
Example standby-blocks:
Example custom.css
WARNING!!
YOU CAN ONLY USE BLOCKS WICH ARE ALREADY AVAILABLE ON ONE OF THE MAIN SCREENS.
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
Example custom.css
.standby .clock{
font-size:60px !important;
.standby .weekday,.standby .date{
font-size:40px !important;
WARNING!!
Blueone
Very nice and fast!! going to test with this and some bold font's etc in the css.robgeerts wrote:DIFFERENT BLOCKS IN STANDBY MODE
Btw, I was trying this which you supplied earlier:
.standby .row {
opacity:1 !important;
} It isn't working on my raspberry, is goed out of standby directly when is goes in stand-by (full screen mode only), in my windows browser is does work, strange.. going to check wat is happening. This did work before the latest change.
- EdwinK
Looks great again Rob.
Clock can be bigger, so looking in to that
axelbaas
This is really superb!robgeerts wrote:DIFFERENT BLOCKS IN STANDBY MODE
I encounter an issue on my Ipad. I think it isn't really an 'dashboard' issue, but maybe some encountered the same issue. And has a solution for it;
When the dashboard is going into 'standby' the only way to 'wake' te dashboard is by tapping the small buttons at the bottom where you can open the second screen. Every other pixel isn't wake the dashboard from standby.. Somebody a solutions?
Clemen
Does anyone else have this problem on iPad?
It started in one of the latest versions.
I created a desktop link to the page, so the pages opens without address bar etc. but in one of the latest versions the pages "crashes" and the iPad goes to springboard again.
I think it happens after a few hours. (iPad is always on, without standby etc.)
- htilburgs
Mmmm.... Standby does give multiple double items??
Hardware:
robgeerts
What if you clear your cache?htilburgs wrote:Mmmm.... Standby does give multiple double items??
Could you try latest version I've just pushed to gitlab?axelbaas wrote: When the dashboard is going into 'standby' the only way to 'wake' te dashboard is by tapping the small buttons at the bottom where you can open the second screen. Every other pixel isn't wake the dashboard from standby.. Somebody a solutions?
Blueone
Somehow it is caused by the mouse move in full screen, when that part is commented out, it is working fine. It is hard to debug because it only occurs in full screen, when the dev console is open in fullscreen it also doesn't occur.Blueone wrote: But this doesn't make the text real white as it is in active mode, do you have some more suggestions to do this?
$('body').bind('mousemove', function(e){
standbyTime=0;
// disableStandby();
robgeerts
I've removed the mousemove part in latest version.
As it is designed for a tablet where mousemove doesnt exists, it isn't needed
- htilburgs
I cleared my cache (also using chrome incognito), but to make sure cleared complete cache. Pulled latest version to make sure, but no luck.
Everything is double... Also a new issue is happening (not sure it has to do something with the dashboard), but I've never had it today until now.
A popup from weer.nl is coming up everytime.
Hardware:
axelbaas
iPad - standyby issue solved in latest version! Thanks a lot!
- htilburgs
Another issue is that the second screen does not goes into the background_night.
After the dashboard came from standby, than the second, third, etc., screen is in the background_night.
PS. the issue with weer.nl is temporarly disabled by removing the URL in button.buienradar.
Hardware:
robgeerts
Strange, I dont have this issue..htilburgs wrote:I cleared my cache (also using chrome incognito), but to make sure cleared complete cache. Pulled latest version to make sure, but no luck.
Anyelse has this problem too??
Till its fixed, remove the columns_standby-variables in your config.
Known issue with the weer.nl-website.htilburgs wrote: A popup from weer.nl is coming up everytime.
Try linking to weeronline.nl, like:
buttons.buienradar = {width:12, isimage:true, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weeronline.nl/Europa/Nederland/Son/4058667'}
- htilburgs
Hardware:
- EdwinK
http://www.weer.nl doesn't want to be 'catched' in another application. Maybe we need another weather-site to get around this.
robgeerts
Let me fix this, hold on!htilburgs wrote:Another issue is that the second screen does not goes into the background_night.
And now I now why you got double items too
Please, be patient, will fix this within the next hour (with one of those lovely beers next to me)
- htilburgs
I wait...
Hardware:
