robgeerts
- Domoticz version: 3.7067
Re: New Dashboard Design v2, custom positioning and multiple screens
Hold on, like I said, this is not so strange, few minutes, let me fix it
- HansieNL
Rainscript devices:
1. On/off switch
2. Text device
1. On/off switch
2. Text device
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 116,
"Data" : "Off",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 2,
"HardwareName" : "Dummy",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "0001416D",
"Image" : "Regen",
"IsSubDevice" : false,
"LastUpdate" : "2017-04-13 01:50:06",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 100,
"Name" : "Regen verwacht",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Switch",
"SwitchType" : "On/Off",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "lightbulb",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "285"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Geen regen verwacht binnen komende 30 minuten",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 2,
"ID" : "00082286",
"LastUpdate" : "2017-04-13 03:55:03",
"Name" : "Regen mm/uur",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"ShowNotifications" : false,
"SubType" : "Text",
"Timers" : "false",
"Type" : "General",
"TypeImg" : "text",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "286"
Blah blah blah
robgeerts
Try latest version!EdKo66 wrote:That is what's confusing me atm.HansieNL wrote:@EdKo66 are you sure this is the right IDX for this switch? Looks like the picture is the on/off switch and the data output looks like the text device to me.
I created a text device, with IDX 113
When I return from the evil that is grocery-shopping, I will take another look at the scripts in that topic and see what I can do.
Nautilus
The default config I started with had screens[1] enabled so yes I've tested that. It's only now when I saw the latest default config I also tried disabling the whole screens sectionkoowee wrote: Try to enable screens (one screen, it should show colums 1-3)
exampleCode: Select all
//if you want to use multiple screens, use the code below: var screens = {} screens[1] = {} screens[1]['background'] = 'bg1.jpg'; screens[1]['columns'] = [1,2,3] //screens[2] = {} //screens[2]['background'] = 'bg3.jpg'; //screens[2]['columns'] = [4,5,6]
- HansieNL
Hello Rob,robgeerts wrote:Try latest version!EdKo66 wrote:That is what's confusing me atm.HansieNL wrote:@EdKo66 are you sure this is the right IDX for this switch? Looks like the picture is the on/off switch and the data output looks like the text device to me.
No text is shown just a switch. I've posted my rainscript info with a picture, so you can see how it looks like in Domotiz.
Blah blah blah
axelbaas
It is working now! I had to change the name of this text box to : 'Rain Expected' . But now it is working.! Tnx!robgeerts wrote:Try latest version!EdKo66 wrote:That is what's confusing me atm.HansieNL wrote:@EdKo66 are you sure this is the right IDX for this switch? Looks like the picture is the on/off switch and the data output looks like the text device to me.
Nautilus
Ok, now I'm getting somewhere. I started with instructions here: https://gitlab.com/robgeerts/dashboard/ ... ositioningNautilus wrote:The default config I started with had screens[1] enabled so yes I've tested that. It's only now when I saw the latest default config I also tried disabling the whole screens sectionkoowee wrote: Try to enable screens (one screen, it should show colums 1-3)
and removed everything and then just added the three columns with idx's as suggested. And suddenly it works.
However, I cannot pinpoint what the issue was at first place. I can now add e.g. the screens and still working...
- EdwinK
- Domoticz version: BETA
Re: Dashticz v2.0, custom positioning and multiple screens
- HansieNL
You still need to install the script correct? If so and need help... just yell
Blah blah blah
- EdwinK
I've got this script. Guess that is the wrong one? I don't see anywhere to place the idx for the switch/text
- Spoiler: show
- HansieNL
You got these two lines in your script? If not you got a different script.
-- Rain switch (ON when rain above threshold, else OFF)
local rainswitchname = "Regen verwacht" -- (str) name for switch to toggle
-- Virtual device (txt) displays textual result
local idxRegenmmUur = 286 -- IDX for virtual (text) sensor
You also got to change the following lines:
-- URL for data rewquest
local requesturl = "http://gadgets.buienradar.nl/data/raint ... lon='..lon"
Blah blah blah
- EdwinK
HansieNL wrote:You got these two lines in your script? If not you got a different script.
Looks like it's a different one. Looking up yours. Is that the one on the first post?
- HansieNL
Nope. I took that one from page 5.
Blah blah blah
- EdwinK
HansieNL wrote:Nope. I took that one from page 5.
That was the one I started with, but installed again. Now hoping it will work.
pkrabben
- Domoticz version: 3.5877
I'm also looking for the right script that I can use.EdKo66 wrote:HansieNL wrote:Nope. I took that one from page 5.
So if anybody have it working can you please share the script
- HansieNL
-- IsItGonnaRain( int minutesinfuture)
-- returns: int avarage rainfall for the next minutesinfuture
-- Function to get rain prediction from Buienradar.nl (dutch)
-- Original script here: https://www.domoticz.com/wiki/Is_it_gonna_rain
-- Written in LUA by Hans van der Heijden (h4nsie @ gmail.com)
-- Spring 2015
-- 28-03-2015 v0.3 bug: quotes around url added.
-- 27-03-2015 v0.2 return value is now average for next time
-- 26-03-2015 v0.1 Initial release
-- todo: some error checking on http and file handling (tmp file)
-- Marco van Wijngaarden
-- 30-08-2016 v1.0 Adopted and updated the above scripts
-- 30-08-2016 v1.1 Updated the request URL, apparently buienrader is redirecting to different url
-- 30-08-2016 v1.2 Updated CURL to follow redirect and reverted (back to documented) request URL
-- Buienradar.nl --
-- Gratis Weerdata --
-- Buienradar stelt gratis weerdata beschikbaar voor particulieren en bedrijven (website/intranet).
-- Het gebruik van onderstaande weerdata is alleen toegestaan voor niet-commerciële doeleinden.
-- Het gebruik voor mobiele toepassingen of commerciële doeleinden vereist toestemming van Buienradar, zie ook de Disclaimer.
-- Vraag hier toestemming aan voor het gebruik van de weerdata: http://www.buienradar.nl/overbuienradar/contact
-- Vragen, suggesties of een leuk idee? Neem contact met ons op en bouw mee aan Buienradar!
-- Buienradar widget - Neerslagdata op basis van coördinaten
-- Op basis van de door u gewenste coördinaten (latitude en longitude) kunt u de neerslag tot twee uur vooruit ophalen in tekstvorm.
-- De data wordt iedere 5 minuten geüpdatet.
-- Op deze pagina kunt u de neerslag in tekst vinden: http://gps.buienradar.nl/getrr.php?lat=51&lon=3
-- De waarde 0 geeft geen neerslag aan (droog), de waarde 255 geeft zware neerslag aan.
-- Gebruik de volgende formule voor het omrekenen naar de neerslagintensiteit in de eenheid millimeter per uur (mm/u):
-- Neerslagintensiteit = 10^((waarde-109)/32)
-- Ter controle: een waarde van 77 is gelijk aan een neerslagintensiteit van 0,1 mm/u.
-- config ------------------------------------------------------------------------------------------------------
-- Set your local position (latitude and longitude)
local latitude = '59.43' -- your home latitude, set as a user variable
local longitude = '12.31' -- your home longtitude, set as a user variable
-- timewindow for prediction
local minutesinfuture = 30 -- (int) minutes in future to calculate rain
-- threshold for switch (when do we actually call it rain and want to act accordingly)
local switchthreshold = 70 -- (int) value to toggle virtual switch
-- Show results in log
local debug = 1 -- 1 = ON or 0 = OFF
-- NMA notifications (only during the day)
local notify = false -- (bool) set 'false' or 'true'
local requesturl = "http://gadgets.buienradar.nl/data/raintext?lat='..lat..'&lon='..lon"
-- redirects to "http://gadgets.buienradar.nl/data/raintext"
-- Where do we store the data (tmp) file
local tempfilename = "/home/pi/domoticz/scripts/tmp/rain.tmp"
-- default to activate script (set 'false' to run once every 5 minutes or 'true' to run every minute)
local active = false -- (bool) set 'false' or 'true'
-- No edit required below this line
-- execute (activate) every 5 minutes
local time = os.date("*t")
if ((time.min % 5)==0) then
-- set to active
active = true
-- Functions ---------------------------------------------------------------------------------------------------
-- function to split a string --
function splitString(str, delim, maxNb)
-- Eliminate bad cases...
if string.find(str, delim) == nil then
return { str }
if maxNb == nil or maxNb < 1 then
maxNb = 0 -- No limit
local result = {}
local pat = "(.-)" .. delim .. "()"
local nb = 0
local lastPos
for part, pos in string.gmatch(str, pat) do
nb = nb + 1
result[nb] = part
lastPos = pos
if nb == maxNb then break end
-- Handle the last field
if nb ~= maxNb then
result[nb + 1] = string.sub(str, lastPos)
return result
-- function to request rain data
function IsItGonnaRain(requesturl,latitude,longitude,tempfilename,minutesinfuture,debug)
local averagerain = 0
local totalrain = 0
local rainlines = 0
-- construct the request URL
local url = requesturl..'?lat='..latitude..'&lon='..longitude
-- print to log
if (debug == 1) then print("| Request URL .............. : " .. url) end
-- now get the data
local trigger_action = 'curl -Lo '..tempfilename..' "'..url..'"'
-- CURL options: -s for Silent (no error messages)
-- -o for Write output to file instead of stdout.
-- -L Follow redirects if the server reports that the requested page has moved (indicated with a Location: header and a 3XX response code)
handle = os.execute(trigger_action)
-- print request result to log
if handle then
print("| CURL Data request ........ : Success")
print("! CURL Data request ........ : Failed")
-- open file and process data
file = io.open(tempfilename, "r")
-- count datalines
local linenbr = 0
-- now analyse the received lines
while true do
line = file:read("*line")
if not line then break end
-- count received lines
linenbr = linenbr+1
-- line/data format is like 000|15:30 per line, we need to split the string
raindata = splitString(line,"|")
rain = tonumber(raindata[1])
linetime = raindata[2]
-- Linetime2 holds the full date calculated from the time on each line
linetime2 = os.time{year=os.date('%Y'), month=os.date('%m'), day=os.date('%d'), hour=string.sub(linetime,1,2), min=string.sub(linetime,4,5), sec=os.date('%S')}
-- calculate the time difference between data/line and os time
difference = os.difftime (linetime2,os.time())
-- When a line entry has a time in the future AND is within the given range, then add/totalize the rainfall
if ((difference >= 0) and (difference <= minutesinfuture*60)) then
-- print (relevant) data to log
if (debug == 1) then print("| Rain data (line) ......... : " .. line) end
-- calculate totals
totalrain = totalrain+rain
rainlines = rainlines+1
-- close the file
file:close()
-- Returned value is average rain fall for next (int) minutes
-- 0 is no rain, 255 is very heavy rain
-- When needed, mm/h is calculated by 10^((value -109)/32) (example: 77 = 0.1 mm/hour)
averagerain = totalrain/rainlines
-- print summary to log
print("| Rain data received # lines : " .. linenbr)
print("| In timerange # lines ..... : " .. rainlines)
print("| Total rain ............... : " .. totalrain)
print("| Average rain calculated .. : " .. averagerain)
return(averagerain)
-- Functions to round a number to the given number of decimal places
-- returns result as string (text)
function round(num, idp)
return string.format("%." .. (idp or 0) .. "f", num)
-- returns result as a number
function round2number(num, idp)
return tonumber(string.format("%." .. (idp or 0) .. "f", num))
-- Note: If the number is rounded in order to be printed (as text) use function "round" (removed the tonumber function)
-- Converting to number then back to string would reintroduce rounding errors, so for numbers use "round2number" function
-- Process -----------------------------------------------------------------------------------------------------
-- start numbering at 1
indexArray=1
-- executes when active (every 5 minutes)
if (active) then
-- when debugging set to 1, writing to log starts here
print("+--------------------------------------------------+")
print("| =============== IS IT GONNA RAIN =============== |")
-- rain variables
local regen = 0
local regenmmUur = 0
local rainstr = ""
-- execute function (for given future minutes)
regen = IsItGonnaRain(requesturl,latitude,longitude,tempfilename,minutesinfuture,debug)
-- round result
if (regen > 0) then
regen = round2number(regen, 0)
-- convert rain to mm/uur
if (regen > 0) then
regenmmUur = 10^((regen-109)/32)
regenmmUur = round(regenmmUur, 3)
-- textual result
if (regen > 0) then
rainstr = tostring("Regen verwacht: "..regen.." (".. regenmmUur.." mm/uur) binnen "..minutesinfuture.." minuten")
rainstr = tostring("Geen regen verwacht binnen komende "..minutesinfuture.." minuten")
-- write value to virtual (text) sensor
if ((idxRegenmmUur) and (regenmmUur)) then
commandArray[indexArray] = {['UpdateDevice'] = tostring(idxRegenmmUur)..'|0|'..rainstr}
indexArray=indexArray+1
-- when debugging set to 1, write to log
print("| Rain text ................ : " .. rainstr)
-- toggle switch ON
if regen > switchthreshold and otherdevices[rainswitchname]=='Off' then
-- send notification during the day
if (timeofday['Daytime']) and (notify) then
commandArray[indexArray] = {['SendNotification']=rainstr}
-- change switch to ON
commandArray[indexArray] = {[rainswitchname]='On'}
-- toggle switch OFF
if regen == 0 and otherdevices[rainswitchname] =='On' then
-- change switch to OFF
commandArray[indexArray] = {[rainswitchname]='Off'}
-- logging end
print("| --------------------- END ---------------------- |")
Blah blah blah
- HansieNL
https://www.domoticz.com/forum/viewtopi ... 40#p128669gielie wrote:@HansieNL
I use the same rainscript but i dont have the switch with text, i never got this to work, can you explain how you got this to work?
Or do i just have to create a text switch with "Rain expected"? Beacause when i do that i only get "Hello world"
Blah blah blah
NotsniwFrancisco
Hello there, I'm new here. I just want to say Wow! Looking really nice.
- EdwinK
So far, the ouput in the log's looks okay i think
Still the tiles are left to work on
17-04-13 13:33:00.026 LUA: +--------------------------------------------------+
2017-04-13 13:33:00.026 LUA: | =============== IS IT GONNA RAIN =============== |
2017-04-13 13:33:00.026 LUA: +--------------------------------------------------+
2017-04-13 13:33:00.026 LUA: | Request URL .............. : http://gadgets.buienradar.nl/data/raintext?lat='..lat..'&lon='..lon?lat=51.86&lon=4.41
2017-04-13 13:33:00.077 LUA: | CURL Data request ........ : Success
2017-04-13 13:33:00.077 LUA: | Rain data received # lines : 0
2017-04-13 13:33:00.077 LUA: | In timerange # lines ..... : 0
2017-04-13 13:33:00.078 LUA: | Total rain ............... : 0
2017-04-13 13:33:00.078 LUA: | Average rain calculated .. : nan
2017-04-13 13:33:00.078 LUA: | Rain text ................ : Geen regen verwacht binnen komende 30 minuten
2017-04-13 13:33:00.078 LUA: +--------------------------------------------------+
2017-04-13 13:33:00.078 LUA: | --------------------- END ---------------------- |
2017-04-13 13:33:00.080 EventSystem: Script event triggered: Rain Expected
pkrabben
I created the script. In what folder do I need to store it. My virtual switch keeps telling "hello World"EdKo66 wrote:So far, the ouput in the log's looks okay i think
17-04-13 13:33:00.026 LUA: +--------------------------------------------------+ 2017-04-13 13:33:00.026 LUA: | =============== IS IT GONNA RAIN =============== | 2017-04-13 13:33:00.026 LUA: +--------------------------------------------------+ 2017-04-13 13:33:00.026 LUA: | Request URL .............. : http://gadgets.buienradar.nl/data/raintext?lat='..lat..'&lon='..lon?lat=51.86&lon=4.41 2017-04-13 13:33:00.077 LUA: | CURL Data request ........ : Success 2017-04-13 13:33:00.077 LUA: | Rain data received # lines : 0 2017-04-13 13:33:00.077 LUA: | In timerange # lines ..... : 0 2017-04-13 13:33:00.078 LUA: | Total rain ............... : 0 2017-04-13 13:33:00.078 LUA: | Average rain calculated .. : nan 2017-04-13 13:33:00.078 LUA: | Rain text ................ : Geen regen verwacht binnen komende 30 minuten 2017-04-13 13:33:00.078 LUA: +--------------------------------------------------+ 2017-04-13 13:33:00.078 LUA: | --------------------- END ---------------------- | 2017-04-13 13:33:00.078 LUA: +--------------------------------------------------+ 2017-04-13 13:33:00.080 EventSystem: Script event triggered: Rain Expected
