robgeerts
- Domoticz version: 3.7067
Re: New Dashboard Design v2, custom positioning and multiple screens
Sorry, previous was not a reply to you, kowee. But, kowee, coukd you send me the complete graph output? (Pm)
koowee
Just to check, did you remove comments from custom positioning part?JoshDinsdale wrote:Hey Guys
Im very new to this, discovered this project just yesterday. Im having some issues getting devices to show. If i have var _USE_AUTO_POSITIONING and var _USE_FAVORITES set as true, i get some favorites show, however if i try and do it manually i cant get anything to show. Weather and clock stuff is fine.
Any suggestions?
CUSTOM POSITIONING:
//screens[2]['columns'] = [4,5,6]
- EdwinK
- Domoticz version: BETA
Would like that too.
Ierlandfan
Sorry, i saw you already asnwered him but for those who don't know how to ouput the graphs
http://domoticz:domoticzport/json.htm?type=graph&sensor=counter&idx=--insert-idx--here--&range=day
Nautilus
I did a git pull after I saw your message about the fix earlier today. It updated at least two files. But it did not change the situation for my dasboard unfortunately. Could it be about the device types I have as favorites? Some RGB dimmers, selector switches etc. (also normal temp/hum sensors)?robgeerts wrote: When did you download it?
I fixed one issue regarding this, this afternoon..
robgeerts
Well, you should at least see something...
Does console (F12) give you an error?
Nautilus
Well, now I have to say I have no idea what happened. I did several "empty cache and hard reloads" after the last git pull, but the issue remained. I checked the console for errors yesterday and there was something but at the time it seemed like it was not the source of the problems and forgot already what it was. Now as I wanted to check again if there is anything I did one normal reload and vóila - all the favorite devices are thererobgeerts wrote:Well, you should at least see something...
Now that this seems to be solved, need to ask if there is some way to change the display name for WU widget? My WU location name for where I live is not very descriptive, it's "pws:NAMEOFTOWN18" and I'd like to show there just "NAMEOFTOWN"..
robgeerts
Later tonight, i'm going to push a new version, with bugfixes reported in this forum.
Please hold on
Please hold on
shadowland
Great dashboard but....
i can't install (noob)
Were do i put the files??
robgeerts
Download the files and place them in a subfolder of the www of Domoticz (or, if you want in a folder on your desktop.
Copy CONFIG-DEFAULT.JS to CONFIG.js and edit this file to fit your needs.
After that, call index.html (including the complete path to that file) in your browser.
For example: http://path.to.domoticz:8080/dashboard/index.html
axelbaas
Can you share your config.js, especially the part which contain the 'IsItGonnaRain' script?. I want to know how to achieve this within my dashboard.SwordFish wrote:(..)
I added the white one with Photoshop and rename the white one.
As for the buienradar, it is a script that I found on the forum that reports if its gone rain within 15 min.
SwordFish
- Domoticz version: V4.11375
It's just a IDX I filled in?axelbaas wrote:Can you share your config.js, especially the part which contain the 'IsItGonnaRain' script?. I want to know how to achieve this within my dashboard.SwordFish wrote:(..)
shadowland
robgeerts wrote:Download the files and place them in a subfolder of the www of Domoticz (or, if you want in a folder on your desktop.
Is there a possibility that i go back to the normall domoticz?
It worked but i don't have any sensor/switches programmed.
- EdwinK
just skip the /dashbord part of the link Rob has given
robgeerts
I suspect you've overwritten your normal Domoticz index.html and did not place it in a subfolder?shadowland wrote:robgeerts wrote:Download the files and place them in a subfolder of the www of Domoticz (or, if you want in a folder on your desktop.
If yes, re-download Domoticz (or is there an easier way?)
If no, remove the path to subfolder in the URL as Edko66 said
shadowland
Yes hahahah but it was a clean install, i think i know the problem now!robgeerts wrote:I suspect you've overwritten your normal Domoticz index.html and did not place it in a subfolder?shadowland wrote:robgeerts wrote:Download the files and place them in a subfolder of the www of Domoticz (or, if you want in a folder on your desktop.
axelbaas
Hmm.. Mine is shown as a normal switch..SwordFish wrote:It's just a IDX I filled in?axelbaas wrote:Can you share your config.js, especially the part which contain the 'IsItGonnaRain' script?. I want to know how to achieve this within my dashboard.SwordFish wrote:
Tried both Text and Light/switch;
IsItGonnaRain General Text Geen regen verwacht binnen komende 15 minuten
Regen verwacht Light/Switch Switch Off-
robgeerts
Text should work
Sometimes, your browser cache is the problem, try pressing CTRL + F5 at the same time... (or clear your cache)
- EdwinK
axelbaas wrote: Hmm.. Mine is shown as a normal switch..
Tried both Text and Light/switch;Code: Select all
IsItGonnaRain General Text Geen regen verwacht binnen komende 15 minuten Regen verwacht Light/Switch Switch Off
Is it one of the scripts on this page? https://www.domoticz.com/forum/viewtopi ... =38&t=5903
- gielie
- Domoticz version: latest β
HI all, first this dashboard is really great, this what i have thus far.
One thing i can't get to work is a live feed of the webcam.
this is the code i have used.
Can some one help to get an live feed instead of a static picture.
buttons.webcam = {width:12, isimage:true, image: 'http://192.168.1.128:9595/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=user&pwd=password&'}- Aeon Labs USB Stick met Z-wave plus
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
