Mi Light wall switch compatibility
tontze
Domoticz version: Beta Ch
Post by tontze »
Found these :
https://www.aliexpress.com/item/AC100V- ... 0.0.t68Ux2
I asked would they work with mi light, thay answered "yes it can, you can buy" which makes me somewhat suspicious .. Has anyone tired these ?
Would be ideal to control one rooms lightning.
-T
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Nautilus
Re: Mi Light wall switch compatibility
Post by Nautilus »
tontze wrote:Found these :
-T
No, that does not seem MiLight compatible, at least it is not a "MiLight" product. Have a look in: http://www.futlight.com/productlist.aspx. Maybe e.g. one of these would fit your requirements: http://www.futlight.com/productlist.aspx?typeid=143
cyberclwn
Domoticz version: 2024.4
Post by cyberclwn »
Hey,
Not sure where you are from, but I use one of these:
https://www.milightwinkel.nl/MILIGHT-4- ... l-rgb-rgbw
It is a real milight one, and works good.
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
tontze
Post by tontze »
-T
I do have one from the futlight list, but they all have same problem, they have 4 zone controls in one touch panel, its pain in the ass to use .. What im loking for is rgb control for 1 zone only, would be easier to use :)
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Nautilus
Post by Nautilus »
tontze wrote:
Nautilus wrote:
Sounds like you need to get more MiLights, then it'll be handy to be able to control more than one group...:) I just noticed the new remotes for 8 groups, will definitely get a couple of those when they come available in AliExpress :D
tontze
Post by tontze »
Ofcource i do use it for "central switch", but in single room, i want to control only that rooms lights, i have milights in all 6 rooms, and in balcony :)
I Asked does the seller guarantee that it will work with mi light, she responsed yes, choose EX4 model. Still, im not satisfied to believe...
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
