Hi guys,
I saw this cheap light switch on AliExpress, it is 433 MHz so in theory is should work with my RFXtrx433E. Can anyone confirm I get this to work?
https://nl.aliexpress.com/item/New-Wire ... 8bc2a5be74
Cheap light switch
TyzzyT
- Domoticz version: 3.5877
Re: Cheap light switch
I think this one will work for sure, because it has a learning feature:
https://nl.aliexpress.com/item/Smart-Ho ... 7a066e3309
harolds
I just bought three of these: https://www.aliexpress.com/item/433-Mhz ... 0.0.Nq0qwO
They all seem to use an PT2262 chip. According to the RFXtrx manual its an Aoke relay (see chapter 7.10). But I'm not fully sure yet. When I setup two new switches by using the Aoke type they do not work as expected. When clicking the switch the relay switches on, but you need to click the switch twice to switch the relay off again. And for one its the same. I'm going to post my findings in another post.
