For Samsung Series K TVs Wake-on-LAN works ok.
See viewtopic.php?f=28&t=16050&p=120590#p120583
Cheers
Per
Samsung Smart TV (on or off)
- perwei
- Domoticz version: 2020.2
Re: Samsung Smart TV (on or off)
Raspberry Pi 3/Raspbian GNU/Linux
Z-Wave.Me Razberry2 Z-Wave controller
3 x Aeotec ZW100 Multisensor 6
1 x Aeotec Smart Dimmer 6
2 x FIBARO System FGWPE Wall Plug
2 x FIBARO Dimmer 2 FGD-212
1 x FIBARO System FGK10x Door Sensor
1 x Popp Wall Controller
strepfen
Dear All,
I would like to ask some help in case of check Samsung TV state check in Domoticz with LUA code.
First I have used this code to check the state of my TV set (with ping command):
This code give a good status of my TV set, but if I want to register an event to the turn on function (ex.: e-mail sending), then it is not a good solution.
Because the above code change almost every second (when ping command run again) the state of the switch to ON state (so I got hundreds of mail to mail box).
So I have changed to the bellow code to avoid this, and registered an user variable for the ON state:
My problem is that the above code working on the first turn on state, and then the off state, but after that the switch always show off state (and the the user variable stuck in ON state).
It looks like to me after the first on state the program change the user variable to "ON", and then when I turn off the TV, then the ping command fail, and LUA scrip give an error message, that the script was running more than 10 sec, and shut down.
So because the script shut down the user variable stay in "ON" condition, and even scrip restart the switch status won't change in the future.
Please can you check my code, and give me a good suggestion to solve this problem?!
Thank you for your support!
ping_success=os.execute('ping -c1 192.168.1.152')
if ping_success then
print("ping success")
commandArray['Nappali TV']='On'
print("ping fail")
commandArray['Nappali TV']='Off'
if ping_success and uservariables['TvStatus'] ~= 'On' then
print("TV Online")
commandArray['Variable:TvStatus']='On'
elseif not ping_success and uservariables['TvStatus'] ~= 'Off' then
print("TV Offline")
commandArray['Variable:TvStatus']='Off'
Nicogluck
Hi,pj-r wrote:There is also a command line client if someone would like to use it:
http://forum.samygo.tv/viewtopic.php?t=5794#p41376
I have it and it works nicely.
How to use this client with a Raspberry Pi ?
I understand that we should compile the source code, but... please remind me how to proceed...
Many thanks.
- mlamie
- Domoticz version: 3.5877
There is a new Samsung TV page in the Domoticz wiki based on samsungctl. You can try that.Nicogluck wrote:Hi,pj-r wrote:There is also a command line client if someone would like to use it:
I understand that we should compile the source code, but... please remind me how to proceed...![]()
Many thanks.
https://www.domoticz.com/wiki/Plugins/SamsungTV.html
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
Nicogluck
Hi,mlamie wrote: There is a new Samsung TV page in the Domoticz wiki based on samsungctl. You can try that.
Sorry, but I don't understand how to install and use the plugin properly.
First, I have install with sudo pip install samsungctl .
When I try the script, I get the following message :
pi@raspberrypi:~$ samsungctl -i --host 192.168.1.120
File "/usr/local/bin/samsungctl", line 9, in <module>
load_entry_point('samsungctl==0.6.0', 'console_scripts', 'samsungctl')()
File "/usr/local/lib/python2.7/dist-packages/samsungctl/__main__.py", line 93, in main
config = _read_config()
File "/usr/local/lib/python2.7/dist-packages/samsungctl/__main__.py", line 37, in _read_config
except FileNotFoundError:
NameError: global name 'FileNotFoundError' is not definedMany thanks to all...
pj-r
- Domoticz version: V3.8650
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
lupo2a
When I run the plugin or try the samnsungctl -i --host=IPADDRESS I'm getting Access Denied message but no request on the TV to allow access to the plugin/command
Any help?
Samnsung UE46F7000 version T-FXPDEUC-1135.0,BT - S
Any help?
Raspberry PI 4
Domoticz: V2023.2
- Aeotec Gen5 EU
- Neo CoolCam Door Detector and plug
- FIBARO FGWPE Wall Plug
- 6 FIBARO System FGRM222 Roller Shutter Controller 2
- Kodi SamnsungTV Yamaha plugin
- pluginn manager
- Netatmo
Domoticz: V2023.2
- Aeotec Gen5 EU
- pluginn manager
- Netatmo
neevamerk
You can detect your TV is on or off with the help of domoticz
Users browsing this forum: willemd and 1 guest
