Amazon Echo to Domoticz Bridge: switches, sensors & more
Alexa, Google Home and Siri
heggink
Domoticz version: 12451
Re: Amazon Echo to Domoticz Bridge: switches, sensors & more
Post by heggink »
Did you put your devices in a room? Unless they are in a room, alexa won't be able to find them.
Verstuurd vanaf mijn HUAWEI NXT-L29 met Tapatalk
DASHTICZ 🙃
P1 meter & solar panel
qwerk
Post by qwerk »
heggink wrote:Did you put your devices in a room? Unless they are in a room, alexa won't be able to find them.
thanks, I did no know that. But almost all my devices are in a room. In the AWS test results I don't see any off my defined rooms. Should I see something there?
"applianceId": "1313",
"manufacturerName": "Razberry",
"modelName": "Switch",
"version": "On/Off",
"friendlyName": "Bewegingsmelder hal",
"friendlyDescription": "Light/Switch",
"isReachable": true,
"actions": [
"incrementPercentage",
"decrementPercentage",
"setPercentage",
"turnOn",
"turnOff"
"additionalApplianceDetails": {
"maxDimLevel": 100,
"switchis": "On/Off",
"WhatAmI": "light"
However I have over 800 active devices, can that be a problem, as far as you know?
qwerk
Post by qwerk »
I have another issue, when testing in AWS I see requests coming in on my reverse proxy, when using Alexa there is nothing in my log.
markk
Post by markk »
Madgeni wrote:
markk wrote:Hi. I followed the original instructions weeks ago and was so pleased to get this working. The update to allow renaming of devices is drawing me in but I don't want to start the whole process again in case I break anything. Is someone able to tell me what are the bits I need to amend please?
All you need to do is:
In Domoticz - under switches
in the Description - put: Alexa_Name:Your Name For Alexa - where Your Name For Alexa is the name you want.
Then Forget and Discover in Alexa app.
This is after you've downloaded, zipped and uploaded the code from github (making sure to update the conf.json to your own settings).
To be sure, download your code from your lambda first, so you can revert back to it with no problem
Thanks Madgeni
I've been messing with this all evening now but still can't get it to work. I changed the name on a couple of switches and then forgot these from Alexa. I then asked Alexa app to discover devices again and I can see the request going through Lambda but the devices don't reappear on the app again and neither does Alexa recognise them. I reloaded the old zip file and they all reappear again but obviously without the renaming functionality. Ive attached the log in lambda in case it gives any clues. Any idea please?
[attachment=0]Alexa.txt[/attachment]
Alexa.txt
(4.2 KiB) Downloaded 49 times
qwerk
Post by qwerk »
Hi Markk, what do you mean with: I can see the request going through lambda.
When you Ask Alexa to discover, then on the AWS website you can follow that process ??
Should the Alexa actions be logged with /aws/lambda/{projectname] ?
There I can only find the tests I did from the AWS website. but none of all the alexa tests I did.
I hope this can help me find my problem.
gr.
Aren
HarryDutch
Post by HarryDutch »
When signing up for an AWS account you need to enter your credit card information. To be honest I'm quite reluctant to leave my credit card information on the internet. I already know that a prepaid credit card is not accepted. Does anyone of you know another way to get an AWS account without a credit card or by using another payment option?
qwerk
Post by qwerk »
HarryDutch wrote:When signing up for an AWS account you need to enter your credit card information. To be honest I'm quite reluctant to leave my credit card information on the internet. I already know that a prepaid credit card is not accepted. Does anyone of you know another way to get an AWS account without a credit card or by using another payment option?
Hi Harry,
a prepaid credit card is accepted . I used pay2d.nl ( for the Dutch)
mycard2go.com is an alternative (same company)
Don't put to much money on the card, after 1 year you have to pay or it is all lost ;-)
HarryDutch
Hi Harry,
Ah! That's great. Thanks very much for this information!
markk
Post by markk »
gr.
Aren
On the page where you upload the zip file in AWS theres an option to test. I tested using the device discovery code at the very end of the manual and all showed up in AWS. Then I went to the alexa app on my phone and pressed discover devices and I could see the progress of this on the same test page in AWS. However, none of my devices are actually updated/discovered with the new version. Works perfectly with the old one though :(
qwerk
Post by qwerk »
markk wrote: On the page where you upload the zip file in AWS theres an option to test. I tested using the device discovery code at the very end of the manual and all showed up in AWS. Then I went to the alexa app on my phone and pressed discover devices and I could see the progress of this on the same test page in AWS. However, none of my devices are actually updated/discovered with the new version. Works perfectly with the old one though :(
ok, thanks. So it seems we have a version issue. I have to wait for a version update.
markk
Post by markk »
I think it's far more likely to be user error on my part than a version issue. I think I'm missing something somewhere. others have this working just fine.
Madgeni
Post by Madgeni »
qwerk wrote:I have another issue, when testing in AWS I see requests coming in on my reverse proxy, when using Alexa there is nothing in my log.
Hi qwerk
So your lambda is in the EU-West, are you using English(UK) or English(US) in your skill? Clearly the lambda is working ok, as the discovery is running (the room plan thing finds devices that are in plans, but does NOT return the room names)
qwerk
Post by qwerk »
Madgeni wrote: Hi qwerk
Hi Madgeni,
my Lambda is in EU-west, I am using English(US).
I have a feeling that my skill is not communicating with Lambda ( if that is possible)
Is there a way to see that my skill is actually using, or trying to use "my" lambda
Madgeni
Post by Madgeni »
Try English(UK) please
qwerk
Post by qwerk »
I Tried UK even German. all gave the same result. ( not a complete rebuild)
Do you think it could be a language issue. If so I will rebuild all with UK and give that a try tomorrow
Madgeni
Post by Madgeni »
Hi -
there seems to be an issue with the discovery, have reverted to the last working version. Please try that one before you start debugging your setup!
Update - think i've fixed it - pull the latest version and try again for me?
Madgeni
Post by Madgeni »
Hi Madgeni,
you can check the Cloudwatch logs in your lambda to see if your skill is calling it or not
qwerk
Post by qwerk »
Hi, I used the fresh code from github.
now on the AWS test it only gives me 2 devices back. I only added alexa_name to 2 devices, so that looks normal.
But I still think, that my skill is never getting to the code on the AWS site.
I Cross exchanged referenced the ARN and the Skill trigger.
What else can I do to test?
The accounts that I use on developer and aws are NOT the same, but that shouldn't matter, I guess.
qwerk
Post by qwerk »
Do you know if there is a way to test at the developer site. I can make typos and I do not get errors.
IS there a skill logging?
Madgeni
Post by Madgeni »
hmm - it should return all devices in room plans, and if they have "alexa_name" set, change their description. Do you have more than 2 devices in room plans?
Re: accounts, I would imagine it *does* need the same accounts. When you use a custom skill, you can use IAM to permission more widely, but i think Smart Home Skill has canned permissioning.
Yes, as I said before, you can use the CloudWatch logs to check the skill - Lambda > Monitoring tab> View logs in Cloudwatch - and where are you putting typos? You don't need to touch the code other than the conf.json
