Presence detection
- Domoticz version: 3.5877
Presence detection
Hi All
I'm new to domoticz and trying hard to get a high learning curve.
I managed to do the basic light switching and now looking into scripting
I found this script about presence detection https://www.domoticz.com/wiki/Presence_detection
I tried this but for some reason my virtual switch (phone) keeps at the off state
I checked that I can ping my Phone => ok
I checked that the check_device_online.py_192.168.3.217.pid file is created (so the script is running)=> ok
Do you have some more tips for me what to check so I can get this running.
Thanks in advance for your reply
Grtz
Paul
Grtz
Paul
- lonebaggie
Re: Presence detection
Beat Version now has new hardware device
System Alive Checker
This will create a switch that will change state when the ping fails or succeeds
- Domoticz version: 3.8153
Stable even
- emme
- Domoticz version: latest
Ping Hardware under RaspBerry PI is quite odd and gives false off sometimes.
This is not related to Domoticz, but its an hardware limitation...
By design, the onboard LAN share a USB BUS instead of being rietcly connected to the CPU.
this means it has to share resurces with all others devices (this also explain why rPI does not use Gbit ethernet )
so... ping could be considered once the device looks to be stable in its state for about 30secs... (obtained by otherdevices_lastpdate) after this perid, you are about 90% sure about its status
...but I repeat.. this is valid for Raspberry PI.... windows should be much more stable!!!
"We always done this way"
- lonebaggie
Thanks for the update .
Im running on Pi 3 . I use to check if my LIghtwaveRF LInk is down . Which apart from me testing it, it never has been. From what you are saying if the PI is under load the ping test fail and give a false reading.
Good to know, I will do some further testing and see if I need another solution
- emme
keep in mind that it is NOT ALWAYS true.... it depends on many facors:
- available power
- cpu load
- network (local) load
- usb load
- other stuff
it could be... that it could give false results... that's why a delayed check would be a great workaround....
PI is a great device... but of course it has some limits....
- available power
- cpu load
- usb load
- other stuff
I'm new to this but I think I found out where the issue is coming from:
I guess the script usedto use a regular ping to check the presence of the device, and now it is using arping
In ping command the option -W 1 meant timeout of 1 second
Problem is that with arping the -w 1 means a timeout of 1 microsecond! This is clearly too short for any device to be able to reply in time (usually the ping is around 100-500 milliseconds)
I removed -w 1 to use the default timeout and it solve the problem \o/
Hope it helps
Cheers
# currentstate = subprocess.call('ping -q -c1 -W 1 '+ device + ' > /dev/null', shell=True)
currentstate = subprocess.call('sudo arping -q -c1 -w 1 '+ device + ' > /dev/null', shell=True)
Hope it helps
Cheers
- Domoticz version: 2021.1
This was exactly what I was looking for (had the same problem). Many many many thanks for sorting this out!
- Domoticz version: 4.9700
Somehow if I check if the script is working I do get this message in SSH.
I already deleted the -w 1 in the .py file but the status of my "device" will still not be updated in Domoticz. I'm sort of a noob in all this so any information would help.
14:17:35- according to domoticz, 192.168.1.15 is offline
14:17:36- 192.168.1.15 online, tell domoticz it's back
File "check_device_online.py", line 117, in <module>
domoticzrequest("http://" + domoticzserver + "/json.htm?type=command¶m=switchlight&idx=" + switchid + "&switchcmd=On&level=0" + "&passcode=" + domoticzpasscode)
File "check_device_online.py", line 96, in domoticzrequest
response = urllib2.urlopen(request)
File "/usr/lib/python2.7/urllib2.py", line 154, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python2.7/urllib2.py", line 437, in open
response = meth(req, response)
File "/usr/lib/python2.7/urllib2.py", line 550, in http_response
'http', request, response, code, msg, hdrs)
File "/usr/lib/python2.7/urllib2.py", line 475, in error
return self._call_chain(*args)
File "/usr/lib/python2.7/urllib2.py", line 409, in _call_chain
result = func(*args)
File "/usr/lib/python2.7/urllib2.py", line 558, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
urllib2.HTTPError: HTTP Error 400: Bad Request
