Teleinfo module EDF P1 Smart Meter - Beta issue
jayjay
Post by jayjay »
Hi everybody
I use a Teleinfo (EDF) USB module to get my power consumption but with the latest beta's updates I got some troubles with the get back datas.
The module is well installed but the datas are coming randomly on domoticz. Sometimes there is a range of 5 min between two datas received and sometimes 2 min.
2017-04-11 11_53_49-Domoticz.png (38.74 KiB) Viewed 839 times
I tried to modify the update frequency to get the data each 30 secondes but nothing, same problem if I set 0 to disable the limitation.
2017-04-11 11_45_31-Domoticz.png (115.27 KiB) Viewed 839 times
Is that someone also has this problem ?
Thank you, have a nice day
jayjay
Re: Teleinfo module EDF P1 Smart Meter - Beta issue
Post by jayjay »
If I rollback to the last stable version, there is not this kind of problem.
The datas are received every 10 secondes.
2017-04-11 14_22_57-Domoticz.png (42.61 KiB) Viewed 836 times
