robgeerts
- Domoticz version: 3.7067
Re: New Dashboard Design v2, custom positioning and multiple screens
And your toon device itself shows the graphs correctly?
- mAiden88
- Domoticz version: 3.7286
Same here, Toon works correctly with Domoticz..robgeerts wrote:Although I do see toonopafstand.eneco.nl is down, Toon still does work correctly here, the latest graph-output (Gas) I get is:
[code
"d" : "2017-04-11 11:00",
"v" : "0.010"
[/code]
I will post screenshots later today, I'm at my work now.. Really should continue with my app now, otherwise school angry.
Anyone can build a fast processor. The trick is to build a fast system.
Blueone
[/quote]robgeerts wrote: You can add css for this in custom.css, like:
body { font-size:10px !important; } .h4, h4 { font-size: 14px !important; }
Thanks for the quick tip! I extracted these items with font sizes in it. I changed those but the blocks are still sized a bit strange (800x480), I thing I'm going to convert the css to percentage and ems instead of the pixels
/* //CUSTOM CSS FILE */
html,
body {
height: 100%;
width: 100%;
body {
font-size:10px;
.newsWrapper { width:80%; height:106px; overflow:hidden; }
#newsTicker { padding:0; margin:10px 0 0 15px; color:#333; }
#newsTicker li {
min-height:72px;
overflow: hidden;
text-overflow: ellipsis;
text-align: left;
font-size: 17px;
color:#fff;
/* edited */
.sunriseholder,
.sunriseholder .wi{
font-size:14px !important;
.sunriseholder .wi-sunset{
padding-left:10px;
.sunriseholder .wi {
padding-right:5px;
padding-top:5px;
.title{ font-size:12px;}
.wi {font-size:30px;}
.fa {font-size:30px;}
.fa.fa-small {font-size:20px;}
h1 {
font-size:35px;
p {
font-size: 16px;
line-height: 1.5;
margin-bottom: 20px;
.trafficrow{
padding-top: 20px !important;
.navbar-default .navbar-header .navbar-toggle {
font-weight: 700;
font-size: 12px;
color: #222222;
text-transform: uppercase;
.navbar-default .nav > li > a:focus {
font-weight: 700;
font-size: 13px;
color: #222222;
.navbar-default.affix .navbar-header .navbar-brand {
color: #F05F40;
font-size: 14px;
.blinds .fa.fa-arrow-up,.blinds .fa.fa-arrow-down,.blinds .fa.fa-stop-circle {
font-size: 20px !important;
margin-right: 3px !important;
.big .weatherloc {
display:inline-block;
margin-top:-2px;
font-size:24px;
font-weight:bold;
.weatherfull > div div.day {
margin-top: 10px;
font-weight: 300;
font-size:13px;
.weatherfull > div div.temp { font-size: 28px; font-weight:400; }
.weatherfull > div div.temp .nightT { display:block;font-size:22px; opacity:.7; padding-bottom: 10px}
.weatherfull i {
font-size:50px !important;
margin:5px auto 0 auto;
opacity:.9;
.btn {
font-family: 'Open Sans', 'Helvetica Neue', Arial, sans-serif;
font-weight: 700;
padding:0px 5px 0px 5px;
font-size:10px;
margin-right:5px;
blocks[524] = {}
blocks[524]['width'] = 12;
blocks[524]['title'] = 'Living room';
Also I'm noticing some small cosmetic issues, temperatur is shown in domoticz with 1 decimal but in the dasboard with two decimals:
- EdwinK
- Domoticz version: BETA
As far as I can see, they do. Toon is a pain in the (*) right now, with all the log-in error's. Even removed the installation and re-added it again. No avail, but I guess that is something for another topic.robgeerts wrote:And your toon device itself shows the graphs correctly?
robgeerts
Indeed, thats better!Blueone wrote: Thanks for the tip, I extracted these items wit font sizes in it. I changed those but the blocks are still sized a bit strange, I thing I'm going to convert the css to percentage and ems instead of the pixels![]()
robgeerts
Could you test both in latest version?Blueone wrote: I also saw something about changing the title in the dasboard with, but this doesn't seem to work anymore in the latests versions. :
blocks[524] = {}
- EdwinK
Also a itsy bitsy tiny 'problem'.
Both tiles are from one IDX.
In the domoticz settings I've set that it should be one tile
ActTime: 1491904091,
ServerTime: "2017-04-11 11:48:11",
Sunrise: "06:55",
Sunset: "20:31",
result: [
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 255,
CustomImage: 0,
Data: "Humidity 71 %",
Description: "",
Favorite: 1,
HardwareID: 21,
HardwareName: "Buienradar",
HardwareType: "Buienradar.nl (Weather lookup)",
HardwareTypeVal: 94,
HaveTimeout: false,
Humidity: 71,
HumidityStatus: "Wet",
LastUpdate: "2017-04-11 11:43:45",
Notifications: "false",
PlanID: "0",
PlanIDs: [
0
Protected: false,
ShowNotifications: true,
SignalLevel: "-",
SubType: "LaCrosse TX3",
Timers: "false",
Type: "Humidity",
TypeImg: "temperature",
Unit: 2,
Used: 1,
XOffset: "0",
YOffset: "0",
idx: "96"
status: "OK",
title: "Devices"
}Running latest BETA on a Pi-3 | Toon® Thermostat (rooted) | Hue | Tuya | IKEA tradfri | Dashticz V3 on Lenovo Huawei Tablet | Conbee
robgeerts
I dont see the value of that setting in the output?
Blueone
Both fixed! Thanks for the quick fixrobgeerts wrote: Could you test both in latest version?
I have to check how I can make is responsive to the 800x480 resolution, I'm seeing some stuf like "@media (min-width: 768px) {"robgeerts wrote:Indeed, thats better!Blueone wrote: Thanks for the tip, I extracted these items wit font sizes in it. I changed those but the blocks are still sized a bit strange, I thing I'm going to convert the css to percentage and ems instead of the pixels![]()
Maybe I can do something wit @media (max-widt:800) or something. I'm going to learn some CSS first
Edit:
I now added this to my custom CSS:
@media only screen and (max-width: 800px) {
/* Block height */
div.mh {
height: 60px;
/* sunrise */
.sunriseholder,
.sunriseholder .wi{
/* clock size */
.h1, h1 {
font-size:25px;
.h4, h4 {
p {
font-size: 12px;
line-height: 1.5;
.block_clock {
padding-top: 10px !important;
padding-bottom: 10px !important;
/* Weather */
.big .weatherdegrees,
.big .weatherloc {
margin-top:-2px;
font-size:20px;
font-weight:bold;
.weatherfull > div div.temp { font-size: 20px; font-weight:400; }
.weatherfull > div div.temp .nightT { display:block;font-size:12px; opacity:.7; padding-bottom: 10px}
.weatherfull i {
font-size:40px !important;
opacity:.9;
text-align: center;
.weatherfull > div div.icon {
border-radius: 50%;
width: 60px;
height: 60px;
margin: 5px auto;
.weatherfull > div div.icon i { color:#fff !important; }
}Code: Select all
jquery.min.js:4 Subresource requests whose URLs contain embedded credentials (e.g. `https://user:pass@host/`) are deprecated, and will be blocked in M59, around June 2017. See https://www.chromestatus.com/feature/5669008342777856 for more details.Maybe a point of attention in the near future.
- EdwinK
It seems there is a problem with the buienradar script. Going to check it there firstrobgeerts wrote:I dont see the value of that setting in the output?
Going to the dentist-office. Back in a few hours. I hope....
SuperMouse
Just a short question.
How can I change the opacity of the blocks to 100%, or remove the squares. I checked all opacity settings but no results.
I am really curious how it looks like with the letters only on the aluminum background.
- HansieNL
You can put this code in the custom.cssSuperMouse wrote:Hi all,
.transbg.col-xs-1,
.transbg.col-xs-2,
.transbg.col-xs-3,
.transbg.col-xs-4,
.transbg.col-xs-5,
.transbg.col-xs-6,
.transbg.col-xs-7,
.transbg.col-xs-8,
.transbg.col-xs-9,
.transbg.col-xs-10,
.transbg.col-xs-11,
.transbg.col-xs-12 {
background-color: rgba(0,0,0,0.0);
Blah blah blah
Bob123bob
You are right, I was displaying 167 and 167_1robgeerts wrote:Did you have '167' and '167_1' at the same time displaying on your dashboard?Bob123bob wrote: For me it's still not working :
device 167 displays now, today and total
device 167_1 displays now, today and total
device 167_2 displays today and total
device 167_3 displays total
Still no way to display 167_1 (now) only![]()
If yes, try only using 167_1 and removing the rest... What does is display?
I can imagine it give some problems when using 167 and 167_1 at the same time.
167_1 only is working perfectly
Ierlandfan
Is it still possible to have for example a bar "some-name" and a bar "Schakelaars" in the first block?
like:
Block1
Some-name
custom switch, custom switch2
Schakelaars
some switches
like:
Block1
Some-name
Schakelaars
some switches
pvm
- Domoticz version: 4.10538
Yes use 2 title blocks
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',1,6,8,9,11,'blocktitle_2','train','traffic']
columns[1] = {}
Ierlandfan
Thanx! Works like a charm!
Ofcourse define it first:
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['title'] = 'some-name';
robgeerts
Nice to read that how older the project gets, the community is able to help eachother more and more
more spare time for me
( But the next new function is almost ready)
- EdwinK
Can't wait to see it ready
Time for you to get your own board here on the forum
Ierlandfan
Finally some time to edit my dashboard!
Probably very easy but can I substitue a rss feed for a local text file?
The graphs for "Lux" aren't working. (which is probably only important for me, that's ok)
robgeerts
Could you send me your graph output?
