Locked
robgeerts
Domoticz version: 3.7067
Re: New Dashboard Design v2, custom positioning and multiple screens
Post by robgeerts »
Dingetje2004 wrote:I would alsolike to have it refreshed without refreshing the whole page every seconded.
Will fix this asap!
heggink wrote: Couple of items:
1) all of my percentage (memory, CPU, sensors) show as on/off. See json output below.
2) Same for 'distance' devices
3) barometer and humidity show 2 decimals (see eralier picture) and barometer uses % instead of hPa (below as well)
Should be fixed in latest version!
heggink wrote: Many thanks again. Couple of beers coming up.
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
@robgeerts you are unstoppable.
Can you add the code for "Geen regen verwacht binnen 15 minuten" see code.
One question, how do i add the charts in the config?
   "ActTime" : 1491641881,
   "ServerTime" : "2017-04-08 10:58:01",
   "Sunrise" : "06:59",
   "Sunset" : "20:23",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "Geen regen verwacht binnen 15 minuten.",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 19,
         "HardwareName" : "Rain expected",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "HaveTimeout" : false,
         "ID" : "00082052",
         "LastUpdate" : "2017-04-08 10:58:00",
         "Name" : "Buienradar",
         "Notifications" : "false",
         "PlanID" : "4",
         "PlanIDs" : [ 4 ],
         "Protected" : false,
         "ShowNotifications" : false,
         "SignalLevel" : "-",
         "SubType" : "Text",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "text",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "53"
   "status" : "OK",
   "title" : "Devices"
mAiden88
Domoticz version: 3.7286
Post by mAiden88 »
@Rob:
Thanks for all you're great work..
EDIT //
Never mind.. I get it! ;)
Anyone can build a fast processor. The trick is to build a fast system.
SwordFish
Post by SwordFish »
Some screenshots. Not ready yet.
page 1.JPG (286.92 KiB) Viewed 2036 times
page 2.JPG (290.83 KiB) Viewed 2036 times
crashingdutchman
Domoticz version: Latest
Post by crashingdutchman »
the popups for nu.nl and radio show really short and automatically close? What could be wrong?
madrian
Post by madrian »
I want to contribute to your project, but I am not very familiar with Gitlab.
I cloned your repository in Fork Git client and I created a new pull request for Hungarian language file. Please check if you see this commit, on your public Gitlab page I can't see it. :?
mAiden88
Post by mAiden88 »
Hmm..
Multi RSS feeds are not possible ??
Ex: Nu.nl & tweakers.net ?
SwordFish
Post by SwordFish »
hpapagaj wrote:Hi,
You have the latest version?
Than you have to use the new config example to create youre new config file.
Its using blocks now or auto positioning(see the config_example)
Clemen
Post by Clemen »
Blinds arrow buttons are reversed
The blinds are down, but i have to click to "down" arrow to open them, and the "up" arrow to close them.
Screen Shot 2017-04-08 at 14.08.52.png (20.32 KiB) Viewed 2016 times
Bob123bob
Post by Bob123bob »
I have an issue when I want to only display energy now in Watt. I use the idx_1 (e.g. '147_1') but I have a empty box follow by today and total. idx_2 for today and idx_3 for total are working fine. When I use 147 without sub value, I can see the 3 boxes working fine.
Can you help me to display only energy now ?
Clemen wrote:Blinds arrow buttons are reversed
I also have this issue because I use inverted blind percentage
Clemen
Post by Clemen »
I also have this issue because I use inverted blind percentage[/quote]
I am using blinds inverted to.
Its funny because in the code only blinds inverted af supported
else if(device['SwitchType']=='Venetian Blinds EU' || device['SwitchType']=='Blinds Inverted'){
								html+='<div class="col-xs-4 col-icon">';
									if(device['Status']=='Closed') html+='<img src="img/blinds_closed.png" class="off icon" />';
									else html+='<img src="img/blinds_open.png" class="on icon" />';
So everyone must have "wrong arrow keys"
I think the right code block should be
else if(device['SwitchType']=='Venetian Blinds EU' || device['SwitchType']=='Blinds'){
								html+='</div>';
								html+='<div class="col-xs-8 col-data">';
									html+='<strong class="title">'+device['Name']+'</strong><br />';
									//if(device['Status']=='Closed') html+='<span class="state">'+lang.state_closed+'</span>';
									//else html+='<span class="state">'+lang.state_open+'</span>';
									html+='<div style="font-size:10px !important;">';
										html+='<a href="javascript:switchBlinds('+device['idx']+',\'Off\');"><em class="fa fa-arrow-up fa-small"></em></a> ';
										html+='<a href="javascript:switchBlinds('+device['idx']+',\'Stop\');"><em class="fa fa-stop-circle fa-small"></em></a> ';
										html+='<a href="javascript:switchBlinds('+device['idx']+',\'On\');"><em class="fa fa-arrow-down fa-small"></em></a>';
									html+='</div>';
								html+='</div>';
							else if(device['SwitchType']=='Venetian Blinds EU Inverted' || device['SwitchType']=='Blinds Inverted'){
								html+='</div>';
										html+='<a href="javascript:switchBlinds('+device['idx']+',\'On\');"><em class="fa fa-arrow-up fa-small"></em></a> ';
										html+='<a href="javascript:switchBlinds('+device['idx']+',\'Off\');"><em class="fa fa-arrow-down fa-small"></em></a>';
									html+='</div>';
								html+='</div>';
whiteduck
Post by whiteduck »
I've tested with some of your device.
Do you want something like:
This is the result in the latest version wich I will publish later today.
Yep looks perfect - sorry away since you made the change so need to test it on Tuesday! Thanks again!
Domoticz on Ubuntu 16.04 LTS VM
RFXCom USB transceiver
Aeon Labs V2 USB (Zwave)
Various HomeEasy, Oregon devices and sensors. Now using Z-Wave Fibaro FGMS-001, TKB TZ88Es
TP-Link IP310 Cameras
whiteduck
Post by whiteduck »
Oh and did you mention charts... YES PLEASE!
htilburgs
Post by htilburgs »
Hi Rob, finaly some time to experiment with the dashboard, in one word: NICE !!
You're gone get drunk of all the beer, but one of these days we have to have a beer at De Zwaan.... ;)
I'm using Fibaro Roller Shutter to control my blinds, but in the Dashboard it is shown as a lamp.
Do I something wrong of is it nog recognized?
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Open",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "HardwareName" : "Aeon Labs Z-Stick GEN5",
         "HardwareTypeVal" : 21,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "ID" : "00000201",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2017-04-08 14:35:27",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 100,
         "Name" : "Rolluik Woonkamer",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "ShowNotifications" : true,
         "Status" : "Open",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Switch",
         "SwitchType" : "Blinds Percentage",
         "SwitchTypeVal" : 13,
         "Timers" : "false",
         "Type" : "Light/Switch",
         "TypeImg" : "blinds",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "741",
         "YOffset" : "287",
         "idx" : "6"
Hardware:
maluko
Re: New Dashboard Design v2, with custom positioning
Post by maluko »
robgeerts wrote:
Dropshot wrote:This dashboard looks amazing!
I've downloaded and extracted the zip to a subfolder in domoticz and changed CONFIG. Question: should it run instantly, or am I missing something, since I don't see a new dashboard?
If you downloaded it to a subfolder, you have to call it like this:
http://192.168.1.20:8084/subfolder/index.html
So, first your regular domoticz-path, then subfolder, then index.html
can´t get work...
i unzip and downloaded to /home/pi/domoticz/master
next change the /domoticz/master/config.js like this:
var _HOST_DOMOTICZ		  	= 'http://192.168.1.50:8080';
so i think that only have to go on browser here:
http://192.168.1.50:8080/domoticz/master/index.html
but cant open!!
need help.
htilburgs
Post by htilburgs »
can´t get work...
but cant open!!
need help.
You have to put it in the /home/pi/domiticz/www/<subfolder>
Then you can call it with http://192.168.1.50:8080/<subfolder>/index.html
Hardware:
koowee
Post by koowee »
can´t get work...
but cant open!!
need help.
I think that you need to move this master-folder under www-folder > /home/pi/domoticz/www/master
Then this address should work http://192.168.1.50:8080/master/index.htm
EDIT: I was too slow :)
maluko
Post by maluko »
htilburgs wrote: You have to put it in the /home/pi/domiticz/www/<subfolder>
Thanks, its working now
i think that the wiki isnt not easy to understand, maybe this can help other to put on.
robgeerts
Post by robgeerts »
I've been gone for a few hours and the forum gets overloaded ;) will fix some things tonight!
Clemen
Post by Clemen »
What about making the background image related to a light switch?
Then it would be posible to have different backgrounds at night, daytime and when the alarm are active and not active
Locked
