Hi everyone,
i have setup a mini weather station using mysensors instructions with a bmp180 and dht22 for humidity.
I receive my data to domoticz and i can see my temp/hum/pressure.
How can i send this data to wunderground? i have created a personal weather station to wunderground but i don't know how to send my data.
Thanks in advance.
Push values to wunderground
gerard76
- Domoticz version: 3.8153
Re: Push values to wunderground
You create a script that sends the data by GETting an url. http://wiki.wunderground.com/index.php/ ... d_Protocol
johnym30
Can't i use http data push from the domoticz interface instead of a script?
gerard76
I mean a script in Domoticz like LUA or blocky.
johnym30
iI understood what you meant but what i am asking is that why http data push is there in domoticz ?
Can i do it from there and if yes how?
For i tried something, but my values although they seem to be pushed to wunderground, it only gets them once and then nothing.
That is what i get on my domoticz log
2017-04-04 17:09:52.803 (MySensorsGateway) Temp (MyTemp)
2017-04-04 17:09:52.809 HttpLink: sending global variable with value: 17.8
2017-04-04 17:09:53.854 HttpLink: response
2017-04-04 17:09:53.855 (MySensorsGateway) General/Barometer (MyBaro)
2017-04-04 17:09:53.867 HttpLink: sending global variable with value: 1017.0
2017-04-04 17:09:55.051 HttpLink: response-
Toulon7559
- Domoticz version: <2025
A lua-script may be a practical & proven way to upload meteo-info from Domoticz to WUnderground.
In this thread you find examples with data not only from a meteo-station, but also a version with data from a BMP180, and not only a version for upload to WUnderground, but also variations for upload to WOW.nl and to PSWeather.
For info originating from a DHT22 you will have to adapt line 6 of the script for a different device than TFA_Nexus.
Obviously you will have to check/adapt the script for elements which you do not have [like Rain, Wind and UV]............
Adaptation can be as simple as putting -- in front of a scriptline which you do not want to be executed.
Pay attention to lines 14 and 15 which require insertion of YOUR WU-accountinfo, and to line 16 which now has a default-interval of 55 minutes:
in practise often a much smaller value as low as 5 minutes is selected to generate a nice picture in WUnderground.
Rule of thumb is that you should upload not more frequent than the interval of measuring the sensor.
johnym30
thanks everyone, finally did it and working with a lua script!!!
