Newbie with scripting how to get the setpoint of thermostat
All kinds of 'OS' scripts
Lebo2d9
Domoticz version: L stab
Post by Lebo2d9 »
I'm new in scripting. I want to read the set point of a thermostat. But i don't know how to get only the set point value.
Below you can find the code i already have
#!/bin/bash
#--Get Domotics Device
curl 'http://127.0.0.1:8080/json.htm?type=devices&rid=181'
And this is what i get in response
   "ActTime" : 1491285800,
   "ServerTime" : "2017-04-04 08:03:20",
   "Sunrise" : "07:11",
   "Sunset" : "20:18",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "17.5",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 4,
         "HardwareName" : "Dummy",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "HaveTimeout" : true,
         "ID" : "0014105",
         "LastUpdate" : "2017-04-02 23:05:27",
         "Name" : "Schakel temperatuur verwarming",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "SetPoint" : "17.5",
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "SetPoint",
         "Timers" : "false",
         "Type" : "Thermostat",
         "TypeImg" : "override_mini",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "181"
   "status" : "OK",
   "title" : "Devices"
I only want to use the SetPoint value but i don't know how i can do this
Can someone help me with that?
Kind regards
Koen
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
emme
Domoticz version: latest
Re: Newbie with scripting how to get the setpoint of thermostat
Post by emme »
you can use JQ utility under bash to parsing JSON data... (install with sudo apt-get install jq )
SETPOINT=$(curl 'http://127.0.0.1:8080/json.htm?type=devices&rid=181' | jq '.restult.SetPoint')
(did not test it.... but it could work like this)
"We always done this way"
Lebo2d9
Post by Lebo2d9 »
Thx for the reply.
The final code is
curl -s 'http://127.0.0.1:8080/json.htm?type=devices&rid=181'| jq -r '.result[] |.SetPoint'
More to come
