Xiaomi Mi Flora [Temp/Light/Moisture] BLE Sensor
Coldman
Re: Xiaomi Mi Flora [Temp/Light/Moisture] BLE Sensor
Post by Coldman »
devros wrote:i have problems with Mi Flora, sensor works only when is really near with script (1-2m) and event then reading is often with timeout,
but when is about 5 meters and one window
connect: No route to host (113)
but with hcitool lescan is visible
LE Scan ...
C4:7C:8D:61:B4:DA (unknown)
C4:7C:8D:61:B4:DA Flower mate
any idea what wrong, is really BE really so poor with signal?
tried to check singal, but dunno what numbers to check
> HCI Event: LE Meta Event (0x3e) plen 35                     [hci0] 115.727966
      LE Advertising Report (0x02)
        Num reports: 1
        Event type: Connectable undirected - ADV_IND (0x00)
        Address type: Public (0x00)
        Address: C4:7C:8D:61:B4:DA (OUI C4-7C-8D)
        Data length: 23
        Flags: 0x06
          LE General Discoverable Mode
          BR/EDR Not Supported
        16-bit Service UUIDs (partial): 1 entry
          Xiaomi Inc. (0xfe95)
        Service Data (UUID 0xfe95): 3102980006dab4618d7cc40d
        RSSI: -77 dBm (0xb3)
[bluetooth]# scan on
Discovery started
[CHG] Controller 34:C3:D2:E4:13:E3 Discovering: yes
[CHG] Device C4:7C:8D:61:F7:83 RSSI: -78
[CHG] Device C4:7C:8D:60:F5:2A RSSI: -82
[CHG] Device C4:7C:8D:61:B2:D2 RSSI: -86
[CHG] Device C4:7C:8D:60:96:75 RSSI: -76
[CHG] Device C4:7C:8D:60:84:99 RSSI: -84
[CHG] Device C4:7C:8D:61:5F:4D RSSI: -86
[CHG] Device C4:7C:8D:60:84:8F RSSI: -74
[CHG] Device C4:7C:8D:61:B6:52 RSSI: -74
[CHG] Device C4:7C:8D:61:B6:62 RSSI: -70
[CHG] Device C4:7C:8D:61:9A:01 RSSI: -92
3-5 meters, connect is ok
devros
Post by devros »
found that BE Mi Flora works only when i restart machine on first try....., on second try i have
so its some BE problem machine :(
EDIT: ok it was problem with old Bluetooth daemon, upgraded to 5.44 version and it works now
tontze
Domoticz version: Beta Ch
Post by tontze »
RSSI is the one to check, lower rssi = better signal, sort of. It still doesnt tell quality of the connection. Connection might be poor, even when signal is strong.
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
tontze
Post by tontze »
devros wrote:found that BE Mi Flora works only when i restart machine on first try....., on second try i have
works wit longer distance too ?
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
devros
Post by devros »
Yup miflora is still on same place and sensor now works....
connect: Device or resource busy (16)
Mi Flora: C4:7C:8D:61:B4:DA
Firmware: 2.6.2
edit: noticed that its not 100% ok sometimes its not working (weird is thas when i run hcitool lescan before script it works almost everytime)
Coldman
Post by Coldman »
Firmware: 2.6.2
if you use App Flower Care on your phone, you should close it!
devros
Post by devros »
Firmware: 2.6.2
i only closed app and disabled bluetooth, or i have to unpair device somehow ?
Coldman
Post by Coldman »
Firmware: 2.6.2
With the last and the penultimate firmware you do not need to pair Bluetooth, there is working perfectly without pairing
dakipro
Domoticz version: 3.5877
Post by dakipro »
how does one upgrade to 5.44 after having installed 5.43?
Is it just running
cd /home/pi
wget http://www.kernel.org/pub/linux/bluetooth/bluez-5.44.tar.gz
tar -xvf bluez-5.44.tar.gz
cd bluez-5.44
sudo ./configure --prefix=/usr --sysconfdir=/etc --localstatedir=/var --enable-tools --disable-test --disable-systemd
sudo make all
and then
export PATH=$PATH:~/bluez-5.44/attrib/
As last time I tried to copy gatttool from 5.44 i got cp: cannot stat 'attrib/gatttool': No such file or directory
Problem is that everything worked fine when I installed the script, and some time after that, but then it sort of stopped. Now if I run script manually I do get some values first time (but I do not see light signal on the flora as I did when I first tested).
But second time I try to manually pull values, I get
osmc@kodi:~/bluez-5.44$ /usr/bin/python3 /home/osmc/miflora/domoticz.py
21: ()
Mi Flora: C4:7C:8D:62:00:EC
connect error: Function not implemented (38)
connect error: Transport endpoint is not connected (107)
Raspberry Pi 2 B - MySensors (dimmers, switches, motion, temperature, lux, humidity sensors)
zWave (220v switches)
various 433 via RFLink
dakipro
Post by dakipro »
And now I tested few more times, and it seems to work... Strange...
Distance between the flora and pi is 4m without obstacles (i tried from 20cm distance, but received also sometimes confused responses)
(bluetooth on phone is turned off, app connects fine each time and gets historical data fine)
Coldman
Post by Coldman »
dakipro wrote:And now I tested few more times, and it seems to work... Strange...
RPi2+USB BT dongle?
Szwuntex
Post by Szwuntex »
dakipro wrote:how does one upgrade to 5.44 after having installed 5.43?
Is Gatttool included in 5.44? I had to go for 5.43 to get Gatttool.
Why do you want to upgrade to 5.44?
madrian
Post by madrian »
Update: after the new update Mi Home on iOs the flower monitor is now successfully connecting. Yeah!
dakipro
Post by dakipro »
Well I was having problems with connecting to the Flora (connect error: Transport endpoint is not connected (107) - see previous post for details), so I was under impression that 5.44 fixed this and wanted to update.
But now I see that everything works fine on my raspberry Pi 3 (onboard bluetooth, wifi not active on the board if that matters)
woodtrix
Post by woodtrix »
I've been looking into the region ban,
It seems there camera are also effected, but blocking a couple of dns hosts works to bypass it, maybe it also works for the miflora app.
https://github.com/fritz-smh/yi-hack/is ... -219249830
Jumper3126
Post by Jumper3126 »
Found a way to connect the "mainland china" sensors to your iphone. You need a jailbreak for it though.
I used "cover my ass" VPN to get an IP address in beijing (free first week). then used Cydia app "protect my privacy" to fake that I'm actually in China.
So, the plant sensor only checks your location at the moment of registering the sensor for the first time in the app. I think it does this based on IP address and phone location. Afterwards it doesnt check anymore. For I understand, this is different to the location block in the camera's, as they continuously check where they are.
madrian
Post by madrian »
I am started to use domoticz.py, it is working fine, but where I can see battery level? Do I need to create a dummy battery device?
In the source I see that we are sending battery level at each device:
val_bat  = "{}".format(poller.parameter_value(MI_BATTERY))
    # Update temp
    val_temp = "{}".format(poller.parameter_value("temperature"))
    domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=udevice&idx=" + idx_temp + "&nvalue=0&svalue=" + val_temp + "&battery=" + val_bat)
...but where I can check this battery level?
pvm
Domoticz version: 4.10538
Post by pvm »
In there device list
madrian
Post by madrian »
Thanks, I found it. :)
I am thinking of replacing the battery with lir2032 rechergeable battery (+solar charger), but it's voltage is higher than regular cr2032. What do you think about higher voltage?
LouiS22
Post by LouiS22 »
hpapagaj wrote:Thanks, I found it. :)
Time will tell. Some devices are tolerate a bit higher juice, but generally it's not a good idea to overfeed any device. Worst case in your case: you kill your sensor.
