How to cut output of svalues in LUA
lassiko
Post by lassiko »
Can someone point me a right direction with the problem i have:
I am using a LUA script to send DHT22 data to esp easy with LCD display.
if devicechanged['outtemp'] then
    commandArray['OpenURL']='http://192.168.0.124/control?cmd=lcd,1,1,Temp:'..otherdevices_svalues['outtemp']..''
As "outtemp" is DHT22, sValues includes humidity as well: 2.5;74.0;0
So on a display i get this: Temp:2.5;74.0;0
I would only like to see temp OR is there a way to display it Temp:2.5c Hum:74.0% This would be even better.
Thank you!
Toulon7559
Domoticz version: mixed
Re: How to cut output of svalues in LUA
Post by Toulon7559 »
Perhaps you first have to separately extract Temp and Humidity from the DHT-set of 3 svalues.
Have myself a simple stepwise script along that line operating on output of a meteo-sensor which provides 4 svalues.
Following is an extract from that lua-script of those segments relevant for you.
In practise I have made 2 scripts, tuned to the designated line for the OLED: one for Temp, one for Humidity
Below you see the version valid/active for Temp, to be tuned for your configuration and application.
-- Lua-script for info-upload to ESP8266 with OLED SS1306
-- (c)2017 Toulon7559 rev. 01
-- Definition of function(s) and Setting of references
function round(num, dec)
   if num == 0 then
     return 0
     local mult = 10^(dec or 0)
     return math.floor(num * mult + 0.5) / mult
baseurl = "http://192.168.x.y/control?cmd=oled"
--  Call Meteo-info from Domoticz-database
Binnen_Temp_RV_Baro = 'WS7000_Temp_RV_Baro'
sTemp, sRV, sComfort, sBaro = otherdevices_svalues[Binnen_Temp_RV_Baro]:match("([^;]+);([^;]+);([^;]+);([^;]+)")
sTemp = round(tonumber(sTemp),1);
print ('Temp = '.. sTemp)
-- sRV = round(tonumber(sRV),1);
-- print ('RV = '.. sRV)
-- sComfort = tonumber(sComfort);
-- print ('Comfort = '.. sComfort)
-- sBaro = tonumber(sBaro);
-- print ('Baro = '.. sBaro)
UploadURL0A = baseurl .. ",3,1,T=".. sTemp .."C"
-- UploadURL0B = baseurl .. ",4,1,V=".. sRV .."%"
-- Perform upload
commandArray['OpenURL']= UploadURL0A
-- commandArray['OpenURL']= UploadURL0B
lassiko
Post by lassiko »
Thanks for your fast reply.
I am very novice with LUA, but trying to modify this to my needs...
Log shows this error:
Error: EventSystem: in temphum_lcd: [string "--..."]:39: attempt to perform arithmetic on local 'num' (a nil value)
   if num == 0 then
     return 0
baseurl = "http://192.168.0.124/control?cmd=lcd"
Ulkolampo = 'Ulkolämpötila'
sTemp, sRV, sComfort, sBaro = otherdevices_svalues[Ulkolampo]:match("([^;]+);([^;]+);([^;]+);([^;]+)")
UploadURL0A = baseurl .. ",1,1,T=".. sTemp .."C"
-- Perform upload
jvdz
Domoticz version: 4.107
Post by jvdz »
Don't think you get the shown error on this version of the script as there is no line 39.
My guess would be that variable sTemp is nil due to the content of otherdevices_svalues[Ulkolampo] ad the regex not returning any value for it.
So what is the exact content of Ulkolampo?
You could add a print( otherdevices_svalues[Ulkolampo]) statement before doing the round so you can see it in the log.
Jos
lassiko
Post by lassiko »
jvdz wrote:Don't think you get the shown error on this version of the script as there is no line 39.
There was a commented lines before actual script. Error comes from a line 6:
Log for Ulkolampo:
LUA: 1.2;80.0;0
jvdz
Post by jvdz »
I see 3 values and you are trying to retrieve 4 values for 4 different variables with this statement:
What do these 3 values represent?
Jos
Toulon7559
Unintentionally (by accident) probably I have caused some confusion:
:-( the remark 'tune it to your own configuration' is rather lighthearted .......
In my lua-script the set of 4 svalues comes from a Meteo-sensor, not from a DHT22.
Domoticz for a DHT22 will only report 3 svalues.
The script-line to be changed is
Appropriate for a DHT-set of svalues is
sTemp, sRV, sComfort = otherdevices_svalues[Binnen_Temp_RV_Baro]:match("([^;]+);([^;]+);([^;]+)")
lassiko
Post by lassiko »
jvdz wrote:I see 3 values and you are trying to retrieve 4 values for 4 different variables with this statement:
That was it. Thank you very much for your help!
lassiko
Post by lassiko »
Toulon7559 wrote:Unintentionally (by accident) probably I have caused some confusion:
Indeed! Thank you for this. All working now! Thanks!
