http requests for open/close/stop window blinds?
tne7laa
Post by tne7laa »
I have window blinds which can be controlled via the dominica website: Open, Close and Stop and are of type Blinds.
Now I want to control them to Open and stop after some seconds. I'm trying a unix shell script with an virtual switch to do this.
The only thing is that I only have On/Off http request of type 'switchlight':
http://192.168.1.11:5901/json.htm?type=command&param=switchlight&idx=109&switchcmd=On
http://192.168.1.11:5901/json.htm?type=command&param=switchlight&idx=109&switchcmd=Off
With this I can only open/close but not Stop.
I want something like for my blinds:
#!/bin/sh
curl "http://192.168.1.11:5901/json.htm?type=command&param=blinds&idx=116&switchcmd=On"
sleep(3)
curl "http://192.168.1.11:5901/json.htm?type=command&param=blinds&idx=116&switchcmd=Stop"
Are there http requests for blinds directly? I can't find them.
Thanks.
tne7laa
Re: http requests for open/close/stop window blinds?
Post by tne7laa »
Ok, I figured it out myself with the help of Fiddler:
Blinds Up:
Blinds Stop:
http://192.168.1.11:5901/json.htm?type=command&param=switchlight&idx=109&switchcmd=Stop
Blinds Down:
Hope it will help someone else...
gerbala
Post by gerbala »
Yes, it helped me. Thank you, pal!
I'm using Domoticz to make my life more comfortable. Because time which I was spending to house keeping now I spend to play with my kids
salopette
Post by salopette »
Thanks for your help
How can I set it to stop the blind after 10, 20, 30 seconds?
