How can I change device name in LUA
How can I change the name of the device in LUA? Is it possible at all?
- lonebaggie
Re: How can I change device name in LUA
You can use a json call :-
[url]http://IPADDRESS:PORT/json.htm?type=command¶m=renamedevice&idx=IDX&name=DEVICENAME[/url]
replace uppercase chars with params
You can call the Json from within LUA use 127.0.0.1 as IP address
Beware command¶m may cause ¶ error see
https://www.domoticz.com/forum/viewtopi ... 61&t=16912
Thanks. But... In browser is OK but in LUA not working
I reordering indeed but still not working. Any ideas?
- jvdz
- Domoticz version: 4.107
It probably would help to show your LUA script so we can see whether that is indeed correct or not.
Jos
Jos
If I set the switch action with link to json it doesn't work
- jvdz
Understood something doesn't work, but you need to provide more information when you want anybody to help.
Jos
Jos
I'm a beginner and I'm just trying to write a script. I started with an switch action for test. And it does not work.
I need a simple script to check if a device is available. If so, it changes its name to $newdevicename so it is invisible.
I would like to customize this script to change the device name
What should I put in the script to work?
ping_success=os.execute('ping -c1 192.168.0.113') --tablet
if ping_success then
print("tablet online")
here link to json to change device name
print("tablet offline")
- lonebaggie
try
HttpPart=("curl 'http://127.0.0.1:8080/json.htm?param=re ... mmand&idx=" .. IDX .. "&name=" .. DEVICENAME .. "' &")
os.execute(HttpPart)
Where the variable IDX is the switch id you want to change and variable DEVICENAME is the new name of the device
- jvdz
I fail to understand why one would want to rename a device to reflect a status. I would simply have a device and set it to On or Off depending on whether it's online or not.
Jos
Jos
- lonebaggie
I think it quite a neat idea by renaming the device $name you can make it disappear from the dashboard and then reappear when its available again.
I might use that to get round the 10 device limit on selector switches if i have 10 selector switches I can have 100 choices super selector and hide the 9 switches that have not been selected
