Controlling Toon [HACKED] from Domoticz
manyakim
Re: Controlling Toon [HACKED] from Domoticz
Hello, i've tried all the above, but still getting the following error message :
2017-03-09 18:46:00.470 Error: EventSystem: in Toon iets: [string "-- Time script runs every minute, intended to..."]:26: attempt to index global 'jsonThermostatInfo' (a nil value)
Did someone was able to adress what's causing this error messages ?
balans
- Domoticz version: stable
I`m also having the same error`s running on a linux system.
applying changes from Domotics arrive on the Toon.
But the info/changes from Toon to Domoticz don`t.
I guess there might be the problem but i dont have any lua knowledge to fix it
I followed the guidings in this topic.
So i guess i might be missing something
I've added several improvements.
- Check each value for a nil value (in case of a failed request)
- Changed all global allocations to local. This is to prevent a memory leak. (This is how LUA works)
- Added a timeout to curl (--max-time) which will prevent the script from running for more than 10 seconds and thus decreasing the warnings, in case Toon can't be reached. Please take note that this will also ignore the values for that particular request.
Please change the line "local json = assert(loadfile "/opt/domoticz/scripts/lua/JSON.lua")()" accordingly
If this script fails, please check if the url "http://127.0.0.1/happ_thermstat?action=getThermostatInfo"(change IP/hostname) can be reached from another device, and returns valid JSON.
-- Time script runs every minute, intended to sync Domoticz with Toon in case the value is changed on the physical device.
-- Updates Toon Thermostat Sensor to value set on Toon
-- Updates Toon Temperature Sensor to value set on Toon
-- Updates Toon Scenes switch based on program set on Toon
-- Updates Toon Auto Program switch to value set on Toon
-- Updates Toon program information text to value set on Toon
local ToonThermostatSensorName = uservariables['UV_ToonThermostatSensorName'] -- Sensor showing current setpoint
local ToonTemperatureSensorName = uservariables['UV_ToonTemperatureSensorName'] -- Sensor showing current room temperature
local ToonScenesSensorName = uservariables['UV_ToonScenesSensorName'] -- Sensor showing current program
local ToonAutoProgramSensorName = uservariables['UV_ToonAutoProgramSensorName'] -- Sensor showing current auto program status
local ToonProgramInformationSensorName = uservariables['UV_ToonProgramInformationSensorName'] -- Sensor showing displaying program information status
local ToonIP = uservariables['UV_ToonIP']
local DomoticzIP = uservariables['UV_DomoticzIP']
local ToonProgramInformationSensorValue;
local json = assert(loadfile "/opt/domoticz/scripts/lua/JSON.lua")() -- For Linux (LEDE)
local handle = assert(io.popen(string.format('curl -m 5 http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
local ThermostatInfo = handle:read('*all')
handle:close()
local jsonThermostatInfo = json:decode(ThermostatInfo)
if jsonThermostatInfo ~= nil then
local currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
local currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
local currentProgramState = tonumber(jsonThermostatInfo.programState)
local currentActiveState = tonumber(jsonThermostatInfo.activeState)
local currentNextTime = jsonThermostatInfo.nextTime
local currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
if currentSetpoint ~= nil then
-- Update the thermostat sensor to current setpoint
if otherdevices_svalues[ToonThermostatSensorName]*100 ~= currentSetpoint*100 then
print('Updating thermostat sensor to new set point: ' ..currentSetpoint)
commandArray[1] = {['Variable:UV_ToonChangedByDomoticz'] = '1'} -- Set variable changed to 1 to prevent script ToonSetPoint from shooting an event at Toon
commandArray[2] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonThermostatSensorName], currentSetpoint)}
if currentTemperature ~= nil then
-- Update the temperature sensor to current room temperature
if otherdevices_svalues[ToonTemperatureSensorName]*100 ~= currentTemperature*100 then
print('Updating the temperature sensor to new value: ' ..currentTemperature)
commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonTemperatureSensorName], currentTemperature)}
if currentActiveState ~= nil then
-- Update the toon scene selector sensor to current program state
local CurrentToonScenesSensorValue = otherdevices_svalues[ToonScenesSensorName]
if currentActiveState == -1 then currentActiveState = '50' -- Manual
elseif currentActiveState == 0 then currentActiveState = '40' -- Comfort
elseif currentActiveState == 1 then currentActiveState = '30' -- Home
elseif currentActiveState == 2 then currentActiveState = '20' -- Sleep
elseif currentActiveState == 3 then currentActiveState = '10' -- Away
if CurrentToonScenesSensorValue ~= currentActiveState then -- Update toon selector if it has changed
print ('Updating Toon Scenes selector')
commandArray[4] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonScenesSensorName], currentActiveState)}
if currentProgramState ~= nil then
-- Updates the toon auto program switch
local CurrentToonAutoProgramSensorValue = otherdevices_svalues[ToonAutoProgramSensorName]
if currentProgramState == 0 then currentProgramState = '10' -- No
elseif currentProgramState == 1 then currentProgramState = '20' -- Yes
elseif currentProgramState == 2 then currentProgramState = '30' -- Temporary
if CurrentToonAutoProgramSensorValue ~= currentProgramState then -- Update toon auto program selector if it has changed
print ('Updating Toon Auto Program selector')
commandArray[5] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonAutoProgramSensorName], currentProgramState)}
if currentNextTime ~= nil and currentNextSetPoint ~= nil then
-- Updates the toon program information text box
local CurrentToomProgramInformationSensorValue = otherdevices_svalues[ToonProgramInformationSensorName]
if currentNextTime == 0 or currentNextSetPoint == 0 then
ToonProgramInformationSensorValue = 'Op ' ..currentSetpoint.. '°'
ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
if CurrentToomProgramInformationSensorValue ~= ToonProgramInformationSensorValue then
commandArray[6] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonProgramInformationSensorName], ToonProgramInformationSensorValue)}
return commandArray"The greatest good you can do for another, is not to share your own riches, but to reveal to him, his own."
- Benjamin Disraeli -
balans
Hi sorry for the late reply
when i reach for toon i get a
but when running youre new script and the modded folder i still and up with the same
{"result":"ok", "currentTemp":"2058", "currentSetpoint":"1800", "currentInternalBoilerSetpoint":"6", "programState":"1", "activeState":"3", "nextProgram":"1", "nextState":"0", "nextTime":"1491490800","nextSetpoint":"2000","randomConfigId":"1681692777","errorFound":"255","connection":"0","burnerInfo":"0","otCommError":"0","currentModulationLevel":"0"}Code: Select all
2017-04-06 13:49:00.998 Error: EventSystem: in toonsync: [string "-- Time script runs every minute, intended to..."]:37: attempt to perform arithmetic on field '?' (a nil value)-
QuasaR
I am also having issue's with the new script.
I think it has todo with the , at the end of the line before the }.
2017-04-06 15:10:04.966 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_synctoon.lua: /home/pi/domoticz/scripts/lua/JSON.lua:1009: /home/pi/domoticz/scripts/lua/JSON.lua:660: expected string's opening quote at char 353 of: {"result":"ok", "currentTemp":"2170", "currentSetpoint":"2100", "currentInternalBoilerSetpoint":"6", "programState":"1", "activeState":"1", "nextProgram":"1", "nextState":"0", "nextTime":"1491503400","nextSetpoint":"2200","randomConfigId":"1804289383","errorFound":"255","connection":"0","burnerInfo":"0","otCommError":"0","currentModulationLevel":"0",}
2017-04-06 15:11:00.313 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_synctoon.lua: /home/pi/domoticz/scripts/lua/JSON.lua:1009: /home/pi/domoticz/scripts/lua/JSON.lua:660: expected string's opening quote at char 353 of: {"result":"ok", "currentTemp":"2170", "currentSetpoint":"2100", "currentInternalBoilerSetpoint":"6", "programState":"1", "activeState":"1", "nextProgram":"1", "nextState":"0", "nextTime":"1491503400","nextSetpoint":"2200","randomConfigId":"1804289383","errorFound":"255","connection":"0","burnerInfo":"0","otCommError":"0","currentModulationLevel":"0",}
2017-04-06 15:12:03.634 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_synctoon.lua: /home/pi/domoticz/scripts/lua/JSON.lua:1009: /home/pi/domoticz/scripts/lua/JSON.lua:660: expected string's opening quote at char 353 of: {"result":"ok", "currentTemp":"2170", "currentSetpoint":"2100", "currentInternalBoilerSetpoint":"6", "programState":"1", "activeState":"1", "nextProgram":"1", "nextState":"0", "nextTime":"1491503400","nextSetpoint":"2200","randomConfigId":"1804289383","errorFound":"255","connection":"0","burnerInfo":"0","otCommError":"0","currentModulationLevel":"0",}
balans
I sorted my problems i had made i typo
temparature instead of temperature in the events list
that was al the cullprit..
running great now. Thank everybody involved for the scripts and modifications on the scripts
now start looking for al solution to read the allready logged power gas from domoticz in the toon. So i`m up for a hint
terrorsource
I want to control my Toon from Domoticz, which is being controlled by HomeBridge (So i can use Siri to set the temperature).
Already have the LUA code in place. it's reading the environment temperature correctly but Domoticz won't update the temperature in Toon when i change it.
Is working, but gives an error in logs:
Does not work, error in logs:
-- Script used for Toon Thermostaat utility device, upon changing temp in Domoticz, temperature is sent to Toon.
for deviceName,deviceValue in pairs(devicechanged) do
if (deviceName == ToonThermostatSensorName) then
if uservariables['UV_ToonChangedByDomoticz'] == 1 then
commandArray['Variable:UV_ToonChangedByDomoticz'] = '0'
SetPoint = otherdevices_svalues[ToonThermostatSensorName]
print('Setting Toon setpoint to '.. SetPoint)
commandArray['OpenURL'] = string.format('http://%s/happ_thermstat?action=setSetpoint&Setpoint=%s', ToonIP, SetPoint*100)
return commandArrayShortend version of 1 of the previous scripts:Error: EventSystem: in ToonThermostat: [string "-- Script used for Toon Thermostaat utility d..."]:8: bad argument #1 to 'pairs' (table expected, got nil)
json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Raspberry
local handle = assert(io.popen(string.format('curl http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
handle:close()
return commandArrayWe need some way to combine those 2 so we get 1 script without errors.Error: EventSystem: Warning!, lua script ToonThermostat has been running for more than 10 seconds
odelay
I got a rooted Toon and followed the procedure to control it with domoticz. Everything seems to work ok exept I can't set the Toon Thermostat from domoticz. The same as terrorsource mentioned.
I also got this error message every minute:
error: EventSystem: in toon: [string "-- Script used for Toon Thermostaat utility d..."]:8: bad argument #1 to 'pairs' (table expected, got nil)
Anyone know how to fix this?
thanks!
thanks!
terrorsource
Well, i'm able to set the temperature with both scripts. still having the error in the logs tho.odelay wrote:I got a rooted Toon and followed the procedure to control it with domoticz. Everything seems to work ok exept I can't set the Toon Thermostat from domoticz. The same as terrorsource mentioned.
thanks!
odelay
Did you changed anything since? because you wrote:
"it's reading the environment temperature correctly but Domoticz won't update the temperature in Toon when i change it."
That is exactly what I experience at the moment.
- EdwinK
- Domoticz version: BETA
Looks interesting to do, even if it was only to control the Toon from Domoticz, something that isn't possible anymore. But... I just don't dare.
marcelr
- Domoticz version: svn 2470
There are plenty people around at the domoticaforum.eu forum to help you out.EdKo66 wrote:Looks interesting to do, even if it was only to control the Toon from Domoticz, something that isn't possible anymore. But... I just don't dare.
DennisD
Sorry, didn't want to open a new topic for this hacked toon question I got. I want to have my gas usage displayed in domoticz did anybody accomplished this? Can't seem to find it.
BlackysBoss
The scripts in the first post works perfectly (After discovering a few typo's and deleting an unused variable).terrorsource wrote:Does not work, error in logs:We need some way to combine those 2 so we get 1 script without errors.Error: EventSystem: Warning!, lua script ToonThermostat has been running for more than 10 seconds
The '10 seconds' problem seems to be caused by Domoticz itself: viewtopic.php?t=12579
Oh, and I'm trying to get rid of the 'Manual' and 'Temporary' setting. I get how it works, but Toon doesn't show this, so what do I need it for in Domoticz?
Correct me if I'm wrong but these states are used by toon? when the schedule is running and the temperature is manually set on Toon itself it will change it state to manual for example. Same applies to Temporary but then just for a limited time without schedule running.Oh, and I'm trying to get rid of the 'Manual' and 'Temporary' setting. I get how it works, but Toon doesn't show this, so what do I need it for in Domoticz?
I've seen some functions indicating JSON output about gas and electric usage when I was browsing in Toon. But since I don't use those features (missing the Zwave sensor adaptor) I cannot verify if they work.Sorry, didn't want to open a new topic for this hacked toon question I got. I want to have my gas usage displayed in domoticz did anybody accomplished this? Can't seem to find it.
try:
http://127.0.0.1/hdrv_zwave?action=getDevices.json "The greatest good you can do for another, is not to share your own riches, but to reveal to him, his own."
DennisD
Already figured out the gas usage, forgot to post it here
For the other values you want to pull from your toon, read this post (bit old, but files still function): https://www.domoticaforum.eu/viewtopic. ... oot#p77453 . I will attach all files to this post just to share!
For the gas_data_json file (modified electricity_data_json file):
Goto http://ip_toon/hdrv_zwave?action=getDevices.json and look for:. The most important bit is the dev_3.1 part because that can be different in other toons. Open gas_date_json.php and search for: now change the dev_3.1 to the one you have in the mentioned url. Make sure you change the ip_toon to the ip your toon has and also make a gasmeter (add virtual sensor) and fill in the idx. If you upload to mindergas you could also add your gas meter value to the following line: Now domoticz will have the actual meter value and you can upload it to mindergas.
"dev_3.1":{"uuid":"eneco-001-018946:hdrv_zwave_68927F8D936", "name":"HAE_METER_v2_1", "internalAddress":"3.1", "type":"gas", "supportsCrc":"0", "CurrentGasFlow":"0.00", "CurrentGasQuantity":"3080.00", "location":"(null)"},Code: Select all
$gasUsage= $parsed_json['dev_3.1']['CurrentGasQuantity']; Code: Select all
$gasUsage= $parsed_json['dev_3.1']['CurrentGasQuantity'] + yourmetervalue;- Attachments
- hackedtoondomoticz.rar
- (3.98 KiB) Downloaded 290 times
JeDr
Add the following to your script_time_synctoon.lua file below the "handle:close()" part at about rule 23:QuasaR wrote:I am also having issue's with the new script.
I think it has todo with the , at the end of the line before the }.Code: Select all
ThermostatInfo = ThermostatInfo:gsub("%,}", "}")
This should be something like:
handle:close()
ThermostatInfo = ThermostatInfo:gsub("%,}", "}") --Add this to replace ,} with } for valid JSON string
qwerk
Hello, I Hacked my Toon and it is working Domoticz.
thanks for that !!
on my main screen I have two errors .
An explanation mark in my WiFi symbol
And an warning sign ,that has to do with not reaching Eneco.
does anyone know a way to remove these?
thanks for that !!
qwerk
thank you , my error on the WiFi sign is gone.marcelr wrote: Sunday 13 August 2017 15:11 Check out this link:
https://www.domoticaforum.eu/viewtopic. ... 165#p77792
