galadril
Domoticz version: latest
Re: Domoticz app 2.0
Post by galadril »
joostnl wrote:In play store, i cant update the app anymore, it stated that I'm removed from the beta program. I bought the premium version in the past.
How can i join the beta program again?
Beta is still the same, nothing changed.
Maybe because the beta went live this week, so there is not specific beta apk at this moment.
ill probably start with a new beta somewhere this week..
galadril
Post by galadril »
Winne0345 wrote: But it isn't behave like expected. The widget is getting bigger, but font size not.
I tried different launchers and all behave like that. What launcher should i use?
good point.. didn't thought of that ;)
joostnl
Post by joostnl »
im on version, 0.1.366 (2283) is this latest?
galadril
Post by galadril »
joostnl wrote:im on version, 0.1.366 (2283) is this latest?
thats weird!!
https://play.google.com/store/apps/deta ... cz.premium
the version is stated on the play store also: 0.1.386
galadril
Post by galadril »
Spitfire wrote: Neither is the type "Door Lock" Image
thanks for the assistance, should be fixed on next release (probably monday)
galadril
Post by galadril »
Gerwin wrote:i will change the temperature from my smartwares radiator valve but that isnt working in the app
Support for your smartwares should be added in the next beta (monday)
Spitfire
Post by Spitfire »
Great work, thanks! :D
fanfan7291
Re: RE: Re: Domoticz app 2.0
Post by fanfan7291 »
galadril wrote:
fanfan7291 wrote: Latest Notifications are not sorted by date and time in descending order.
Within a day, time before and after noon are mixed together.
So a notification at 6 am appears before a notification at 3 PM.
Hmmm, ill look into it!
fanfan7291 wrote: Would it be possible to add the latest notifications screen as a direct option in the left panel of the app with the same layout than the logs option ?
Sorry Im not in favor of that feature.
Thanks.
Envoyé de mon thor en utilisant Tapatalk
Pixal
Domoticz version: 4.10199
Post by Pixal »
After today's beta, I can't open the app anymore. It repeats to crash, even after reboot of the phone.
Do I need to uninstall and reinstall?
galadril
Post by galadril »
Pixal wrote:After today's beta, I can't open the app anymore. It repeats to crash, even after reboot of the phone.
Sad to hear that, I see the crash reports, ill fix asap
galadril
Post by galadril »
There should be a new beta.. please test again
svenker
Domoticz version: Latest
Post by svenker »
Hello!
I am planning to buy a Samsung Gear S3 which is running on Tizen OS and not Android Wear.
I didn't check but I would imagine that the Gear S3 is by far the most sold Smartwatch around, I imagine that the Domoticz Team is working on the Tizen OS ?
This would be really fantastic!
Thanks in advance
Sam
Pixal
Post by Pixal »
Working well again, thanks!
joostnl
Post by joostnl »
On the bottom in play store i could re join the beta program. So everything's fine now
thats weird!!
galadril
Post by galadril »
svenker wrote:HI didn't check but I would imagine that the Gear S3 is by far the most sold Smartwatch around, I imagine that the Domoticz Team is working on the Tizen OS ?
I don't have any plans at this moment (don't own one either).
I did implement Android Wear OS
CronoS
Post by CronoS »
A quick question, hopefully I can post it here:
- Is it possible to add a function that you can use nfc tags when the device is locked? Always need to unlock it before I can use a nfc tag?
- Also geofencing is not working stable, I always get a notification.. so it is detected, but the switch is not always flipped ? Anyone familiar with this issue and is there a way to work around it?
I use a samsung s7 with the paid version off the app, running on nougat..
Blueone
Post by Blueone »
After using an Iphone 2 years I went back to android and installed this app which wasn't there two years ago but wow :o , a really nice and good app! keep up the good work :)
Thomasdc
Post by Thomasdc »
Hi!
I have a question regarding the Widgets
I like this because this makes 'shortcuts' right on the home screen from my phone.
But i used to have 'imperihome' and there the 'shortcuts' were not Widgets but simple 'shortcuts' --> this give te benefit of grouping them in a folder
So this i my request --> instead of using widgets, using 'shortcuts' that can be placed in a folder on the homescreen
--> 1X1 widget for togle devices
or add an option 'create shortcut' from a scene/toggleswitch (just like imperihome does)
why?
grouping is just nice, and also to prevent unwanted touches
(i have a button to open the gate --> so when i accidentally push it it will open --> when its in a folder i need to open the folder first and than te button --> that way i wont accidentally open the gate and if i want to open te gate its still verry fast accessible.)
I also have a 'graphic/design' proposal for with the widgets .. would it be possible to add the option 'no background/fully transparant background' ?
galadril
Post by galadril »
Blueone wrote:After using an Iphone 2 years I went back to android and installed this app which wasn't there two years ago but wow :o , a really nice and good app! keep up the good work :)
:) thanks!
bueno79
Domoticz version: 4.9700
Post by bueno79 »
Hi Galadril,
still using the app everyday. It is my universal remote now :)
I just get a Hub harmony from logitech (not support in the current stable domoticz...logitech problem but fix in the next release). So I've use the harmony apps. I see thay put shortcut ON the lock screen. Is it possible to do the same ? Get a button to open a gate or garage directly...don t have to unlock the phone...it could be great.
and for people who test geofencing with the apps ? It is better now ? no false detection? no more battery draining ?
best regards and very good job.
Bueno
PS : oh and sometime I'm watching you playing battlefield :p
