Hi there,
I have some issues with reacticz regarding my installation. I'm using a Synology NAS (IP address 192.168.1.2), with the following setup:
- Domoticz is running on a docker container, exposing port 8080 (http). I can access domoticz from outside my home network thanks to the DSM integrated inverse proxy, forwarding home.mydomain.com on port 443 (https) to port 8080. This is working very well.
- I have then installed Mosquitto on another container, exposing ports 1883 and 9883 (configured with websockets). Domoticz is correctly interfaced with Mosquitto, and both are working well together (this is confirmed in Mosquitto log files).
- I have installed the pre-build release v0.1.11 of reacticz inside the www/ folder of domoticz.
Here is now my problem:
- accessing reacticz from my home network, from the address
http://192.168.1.2:8080/reacticz/, and configuring both MQTT and domoticz connections by specifying their local address (ws://192.168.1.2:9883 and
http://192.168.1.2:8080 respectively) works well, and I'm able to make reacticz working well.
- but, if I try to access reacticz from outside my home network, from
https://home.mydomain.com/reacticz/, I'm not able to make it access my MQTT broker (which is not accessible from the outside, since this is not required for now). For domoticz, using
http://192.168.1.2:8080 does not work anymore, I have to specify the "public" address (
https://home.mydomain.com) for the pairing to be OK. For Mosquitto, using ws://192.168.1.2:9883 does not work anymore, and I have no idea on what I can use here now.
Do you have any hints on what's happening? Reacticz seems confused by the way i'm connecting to it: from my local home network, or from the outside.
