LUA script question?
Walduss
Domoticz version: Stable
Post by Walduss »
Hi guys
Could someone explain me this strange behavior?
I have dummy switch which show me state of internet connection.
I used script to update it as below
ping_success=os.execute('ping -c1 8.8.8.8')
if ping_success then
	print("ping success")
	commandArray['Internet']='On'
	print("ping fail")
	ommandArray['Internet']='Off'
I named it as: script_time_internet, so it will be executed every min.
But in log in switch i have data every 3 seconds. Why not every 1min?
2017-03-23 13:12:44 On
2017-03-23 13:12:40 On
2017-03-23 13:12:37 On
2017-03-23 13:12:34 On
2017-03-23 13:12:31 On
2017-03-23 13:12:28 On
2017-03-23 13:12:25 On
2017-03-23 13:12:22 On
2017-03-23 13:12:19 On
What magic is here that it runs every 3sec not 1min?
jvdz
Domoticz version: 4.107
Re: LUA script question?
Post by jvdz »
You created this script in the internal editor and have All under the Lua dropdown?
This means the this script will trigger on ALL events, so whenever any device changes or Time changes.
Change All to Time should fix it.
2 comments:
I would only set the dummy switch when it is not the same, so test against the current value.
.. but more importantly: I would never add a script to the event system as it is single threaded, meaning that all your scripts/logic will be delayed in responding till the ping command is finished (which seems to be about 3 seconds in your case)
Jos
Walduss
Post by Walduss »
Thanks Jos for suggestions.
I created in internal editor but need to check if this is set to "ALL".
This is good point but first I wanted to understand why I got this results, so for sure I will optimize this script and set new value only when will be different than current.
I'm still fresh in this topic, can you write more about it? How to do this in more efficient way?
It will be nice to avoid mistakes on the begining :)
jake
Post by jake »
I use the built in ping option in Domoticz. No need for scripting at all
Walduss
Post by Walduss »
Mystery solved :) I didn't check time option in built in editor. Thx.
Where I can find it? I check all option but I don't see it...
HansieNL
Post by HansieNL »
Hardware - Type - System Alive Check
I use the following settings:
Settings
Poll Interval: 30
Ping Time-out: 1000
Node
Timeout: 60 or 90
Blah blah blah
Walduss
Post by Walduss »
Thanks a lot for helping!!
It works very good !
