Control Your Harmony Hub with Domoticz (RaspberryPi (Linux))
- mbliek
I added a wiki page to control your Harmony Hub with Domoticz.
http://www.domoticz.com/wiki/Harmony_Hub_Control
Op zoek naar een Domoticz Start Set?
- gizmocuz
Re: Control Your Harmony Hub with Domoticz.
Thanks... this remote is still on my 'want to have' list...
Still native support would be better because lua scripts might slow things down
- mbliek
It doesn't use lua script. I did first. But now with sub/slave devices.
- gizmocuz
Question, should the exec functions not start with a slash?
exec `/home/pi/HarmonyHubControl
- mbliek
Nope. All of my scripts are executed without the slash.
Maybe with slash it works also.
Can't try that. I'm not at home.
- mbliek
A screenshot of my Harmony Hub activities.
vinnalott
Hmm.. Nice. Could this device also controll the heatpump/air conditioner?
- mbliek
If it's controlled by IR it should be possible.vinnalott wrote:Hmm.. Nice. Could this device also controll the heatpump/air conditioner?
Derik
- Domoticz version: BETA
I would also like to buy this hub.[ or a one for all nevo ]
Only this is working in Domoticz.....
A few questions.
He also still works well in domoticz?
Can I control everything in Domoticz? [Create unlimited buttons? ]
He work well without the real remote, so only with tablet and phone?
Are there any conditions to the resolution in the hub?
Is the learning function also in this hardware?
Does the hub properly works without boosters?
How long is the wire from the boosters? [Also to extend? ]
What strikes you?
Pleas will you answer.....
A few questions.
What strikes you?
- mbliek
All question about the hub can be found on the internet. Please use google.
I'm still using the hub in domoticz every day.
You can only control "events" in domoticz. For example: watch television, this does turn on the tv, audio receiver and the cable receiver.
Derik
I have bought one.
So I'm experiencing
I hope you can help me if I get stuck ..
So I'm experiencing
- mbliek
Let me know if you have any questions.
Raspberry Piet
Send me a PM at the time when it is also possible to send specific IR-codes, then i will run to the shop to buy one!mbliek wrote:You can only control "events" in domoticz. For example: watch television, this does turn on the tv, audio receiver and the cable receiver.
In the meantime i keep on using the LIRC solution.
Derik
Maybe there is a way to implement the web interface from the Logitech in the domoticz
EDIT:
No webinterface....
whaaaa
I got him!
Hard working to get it....
EDIT:
No webinterface....
whaaaa
I got him!
Derik
Bizarre toy ..
All credits for the builder!!
I got it quite working for a starter ....
There are even more options available, volume, channels, etc
Or can only be controlled? Activities
Is there perhaps a possibility of faster switching, it takes a while before he turns ...
Do you have pictures / experience of working hue bulb??
How did you get those icons?
Thank you!
Thank you!
- mbliek
Only activities are Usable with this solution.
Switching can't be faster, cus every time you press the button in domoticz the script needs to connect to the Logitech server.
I don't have any experience with hue bulb.
Icons must be added to the folder images and in the file switch_icons.txt
Yihaaa
Thank you very much for this script/program!
I've got it also working.
Can you please send the icons? (or give a link where I can get these icons?)
Than also; is it than just a matter of add the icons (JPG) to the images folder?
Let's ask it this way cause I'm a noob; can you please explain how I can add the icons?
Thanks a lot!
Thanks a lot!
Yihaaa
Would it be possible that you can share your icons? Or give a link where the icons to be found?
markk
Hi. Forgive me if this is a stupid question. I have just ordered my Harmony Hub and intend to follow the wiki to incorporate it with Domoticz. Thing is, I have Domoticz running on a window PC and not on a Pi. Could I still do this? Thanks
- mbliek
Well. The original script is for windows. But I can't help you with that. You should check the site of the developers.
