Hei.
I want to turn on lights ect by calling the JSON with Windows command line.
Is this somthing I can do? and how?
Call a JSON from Windows Command line
- bbqkees
- Domoticz version: 4.1x
Re: Call a JSON from Windows Command line
Not sure if that is possible without additional software.
you can also just type it into the browser. That will work for sure.
- robpow
- Domoticz version: Beta :)
Here are two options
Download 'curl' for Windows here:
https://curl.haxx.se/dlwiz/?type=bin&os ... cpu=x86_64
Or try and run the Windows PowerShell command 'Invoke-WebRequest':
https://technet.microsoft.com/en-us/lib ... .620).aspx
rlschulz
- Domoticz version: 3.5877
I did this to send an off to a switch to make an actual momentary switch for a garage door opener.
y=IDX number of device.
That works well.
x= IP
That works well.
