EDIT: Now modified to work with dzVents version 2.0.0 and higher
I've been inspired by this script: Lua script for controlling humidity in the bathroom and I got some design tips from @dannybloe.
My house has a single fan that extracts air from all the rooms in the house. I can force that single fan to work at a higher speed in case of that the humidity in one of my bathrooms rises quickly. My script currently supports only a single fan but multiple humidity sensors. The script also supports a button that can be pushed manually in case that the air quality in the bathroom requires that. I may improve my script and update this first post if I get any suggestions for improvements from you guys. Please feel free to suggest improvements etc.
Here it goes:
bathroomHumControl.lua by BakSeeDaa
Version 1.3.1
This script controls the humidity in a typical bathroom setting by detecting
relative rises in humidity in a short period.
local FAN_DEVICE = 'Nibe F750 Force Fan' -- Fan device
local FORCE_FAN_DEVICE = 'Flatulence Button' -- (Optional)
local FORCE_FAN_TIME = 10 -- Minutes to force the fan when button pushed
local HUMIDITY_SENSORS = {'Badrum 1 C+RH', 'Badrum 2 C+RH'}
local FAN_DELTA_TRIGGER = 3 -- % Rise in humidity that will trigger the fan
local FAN_MAX_TIME = 24 -- Maximum minutes that the fan can be on in case we never reach the target humidity
local TARGET_OFFSET = 2 -- Fan goes off if target + offset is reached
local TEST_MODE_HUMIDITY_READING = 0 -- Set to a value between 1 and 100. Set to 0 to disable test mode
local READING_SAMPLES = 15
-- Create the data declarations
local data = {}
for i, device in pairs(HUMIDITY_SENSORS) do
data[device] = {history = true, maxItems = READING_SAMPLES + 1}
data['dehumidProgramActive'..i] = {history = true, maxItems = 1} -- Need history to get time stamp
data['forceFan'] = {history = true, maxItems = 1} -- Need history to get time stamp
data['targetHum'..i] = {initial=0}
active = true,
logging = {
--level = domoticz.LOG_DEBUG, -- Select one of LOG_DEBUG, LOG_INFO, LOG_ERROR, LOG_FORCE to override system log level
marker = "bathRoom"
devices = {
FORCE_FAN_DEVICE
timer = {
'every 1 minutes'
data = data,
execute = function(domoticz, device, triggerInfo)
local forceFanReadings = domoticz.data.forceFan
if (triggerInfo.type == domoticz.EVENT_TYPE_TIMER) then
local fanCmd = 'Off'
for i = 1, #HUMIDITY_SENSORS do
local humidityReadings = domoticz.data[HUMIDITY_SENSORS[i]]
-- Store the read value in the persistant data
for j = 1, (humidityReadings.size == 0 and READING_SAMPLES + 1 or 1) do
humidityReadings.add((TEST_MODE_HUMIDITY_READING == 0
and domoticz.devices(HUMIDITY_SENSORS[i]).humidity or TEST_MODE_HUMIDITY_READING))
-- INIT
local programActiveReadings = domoticz.data['dehumidProgramActive'..i]
if (programActiveReadings.size == 0) then
domoticz.log('programActiveReadings, Initialization was needed', domoticz.LOG_INFO)
programActiveReadings.add(false)
local targetHum = domoticz.data['targetHum'..i]
if (targetHum == nil) then
domoticz.log('targetHum'..i..', Initialization was needed', domoticz.LOG_INFO)
domoticz.data['targetHum'..i] = 0
targetHum = 0
if (forceFanReadings.size == 0) then
domoticz.log('forceFanReadings, Initialization was needed', domoticz.LOG_INFO)
forceFanReadings.add('Init')
local programActiveState = programActiveReadings.getLatest()
if (programActiveState.data) then -- The fan control program is active
-- Has the fan control program timed out or have we reached the target humidity?
local maxTime = (programActiveState.time.minutesAgo > FAN_MAX_TIME)
local targetHumReached = (humidityReadings.getLatest().data <= targetHum)
if (maxTime or targetHumReached) then
domoticz.log('Dehumidification program stops for: '..HUMIDITY_SENSORS[i], domoticz.LOG_INFO)
domoticz.log('Reason(s): '..(maxTime and 'Max time. ' or '')..(targetHumReached and 'Target humidity reached.' or ''), domoticz.LOG_INFO)
domoticz.log('Dehumidification program is active for: '..HUMIDITY_SENSORS[i], domoticz.LOG_INFO)
fanCmd = 'On'
else -- The fan is currently not running under the control of this program
-- Has there been a significant rise in humidity lately?
local humDelta = humidityReadings.getLatest().data - humidityReadings.min(2, READING_SAMPLES + 1)
-- Calculate a target humidity but never try to push humidity below 40
targetHum = math.max(humidityReadings.min(2, READING_SAMPLES + 1) + TARGET_OFFSET, 40)
if (humDelta > FAN_DELTA_TRIGGER and humidityReadings.getLatest().data > targetHum) then
domoticz.data['targetHum'..i] = targetHum
programActiveReadings.add(true)
fanCmd = 'On'
domoticz.log('Dehumidification program starts as a respond to: '..HUMIDITY_SENSORS[i], domoticz.LOG_INFO)
domoticz.log('Dehumidification program doesn\'t run for: '..HUMIDITY_SENSORS[i], domoticz.LOG_INFO)
domoticz.log('targetHum: '..targetHum..', Current humidity: '..humidityReadings.getLatest().data..', humDelta: '..humDelta, domoticz.LOG_INFO)
if ((forceFanReadings.getLatest().time.minutesAgo < FORCE_FAN_TIME)
and (forceFanReadings.getLatest().data == 'On')) then fanCmd = 'On' end
if (domoticz.devices(FAN_DEVICE).state ~= fanCmd) then
domoticz.log('Turning the fan '..fanCmd, domoticz.LOG_INFO)
domoticz.devices(FAN_DEVICE).toggleSwitch()
-- The script gets executed due to a device-change event
if (device.name == FORCE_FAN_DEVICE and device.state == 'On') then
forceFanReadings.add('On')
domoticz.log('The fan has been forced on for '..FORCE_FAN_TIME..'minutes.', domoticz.LOG_INFO)
-- domoticz.helpers.speak(domoticz, 'joke sting')
if (domoticz.devices(FAN_DEVICE).state ~= 'On') then domoticz.devices(FAN_DEVICE).switchOn() end
}Version 1.3.1.
- Corrected an issue where the force button made the script run a faulty number of minutes.
