Milight newbie: How many bulbs?
ivarka
Post by ivarka »
Hi!
Got a Wifi iBox Controller (iBox2) in the mail and a bulb to play with. Works fine with domoticz (thanks!)
But can I control only four bulbs with this controller?
Ivar
deennoo
Re: RE: Milight newbie: How many bulbs?
Post by deennoo »
ivarka wrote:Hi!
Ivar
10 bulbes / group : 40 Bulbs max
http://domo-attitude.fr
Nautilus
Post by Nautilus »
deennoo wrote: 10 bulbes / group : 40 Bulbs max
Where is this info coming from? How would the bulb receiving the UDP package know how many other bulbs there are in the same group? :D In MiLight documentation it is stating everywhere that you can have unlimited bulbs per group. Currently my biggest group is 18 bulbs...:)
ivarka
Re: Milight newbie: How many bulbs?
Post by ivarka »
But I have to place each bulb in a group and all the bulbs in a group will do the same?
tontze
Domoticz version: Beta Ch
Post by tontze »
ivarka wrote:But I have to place each bulb in a group and all the bulbs in a group will do the same?
If you have rflink and nrf, group number is unlimited then.
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
deennoo
Re: RE: Re: Milight newbie: How many bulbs?
Post by deennoo »
Yeap your right
Max bulb is 400/group as explain on limitless faq
Nautilus
Post by Nautilus »
deennoo wrote: Max bulb is 400/group as explain on limitless faq
Hmm, I saw on the faq section a mention of 200+ bulbs per group/zone (link), but e.g. in this picture http://www.limitlessled.com/images/Limi ... lution.jpg the term "unlimited bulbs" is again used :) Guess there is some sort of limit of how many bulbs you are able to fit to the area of the bridge's / remote's range, but as the bulbs themselves are not aware of what is happening around them and the remote / bridge just sends UDP packages through the air, I don't see how there could be any fixed limit on the number of bulbs? In any case it is safe to say this limits is not easily reached.
tontze wrote:If you have rflink and nrf, group number is unlimited then.
Well, at least here "unlimited" is maybe a bit of an exaggeration :) The size of the "ID-pool" is limited - though not easily reached...
ivarka
Post by ivarka »
Have to get a rflink then :-) Thanks!
Nautilus
Post by Nautilus »
ivarka wrote:Have to get a rflink then :-) Thanks!
An excellent option, I'm sure, especially in the future (I have it as well :)). But I must mention the current Milight implementation in RFLink is not without its flaws yet. If you search the forum you can see what type of problems users have had...
