Only 'on' at switches
EdwinK
Post by EdwinK »
Version: 3.7067
Build Hash: eef0785-modified
Compile Date: 2017-03-20 11:00:54
Running on: Synology NAS
I wanted to make a switch that would turn on/off lights at a fixed time, but I can only select 'on', not off.
Image Image
Lusch
Domoticz version: 3.5837
Re: Only 'on' at switches
Post by Lusch »
Make a virtual sensor and base a script on that sensor value.
simonrg
Domoticz version: 3.8807
Post by simonrg »
You should be able to set on / off / dimmer level even, so it looks like something is wrong, it could be a number of things.
The edit screen for the switch would say what type of light it is, if it is set as push on, then there won't be an off.
Alternatively, this looks like your browser cache needs flushing. Try on a different browser do you still only have one choice?
Do any of your lights give you an off option?
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
