How to: Motion sensors from iSpy camera's
bbqkees
Domoticz version: 4.1x
Post by bbqkees »
I am using (the free) iSpy software for my IP camera's.
In the software there is a function that can send a HTTP request when f.i. motion is detected.
You can use this in Domoticz to trigger a virtual sensor.
Step 1:
Create a virtual switch in Domoticz and set it to the Motion Sensor type.
Write down the device ID.
Step 2:
Go to iSpy and select the camera you want to use as a motion detector.
Go to Settings and then the tab Alerts.
Now you need to create 2 rules with the type 'Call URL'.
One rule for 'Alert' and one rule for 'Alert Stopped'.
Say the device ID of your virtual sensor is '228' and the IP address of your Domoticz is 192.168.1.100 with port 8080.
Rule for 'Alert':
http://192.168.0.100:8080/json.htm?type=command&param=switchlight&idx=228&switchcmd=On
make sure you enable the rule by clicking on the checkmark!
Uncheck 'Send image'.
Rule for 'Alert Stopped':
http://192.168.0.100:8080/json.htm?type=command&param=switchlight&idx=228&switchcmd=Off
What you get is this:
It works pretty well.
PSYCHOTIC
Re: How to: Motion sensors from iSpy camera's
Post by PSYCHOTIC »
Cool feature!
Does anyone know a free android equivalent to ispy? (Stand alone android motion app send json)
I want to use this to monitor a blinking led for my energy consumption.
Great thx.
Marzel
Post by Marzel »
Tried this, but it doesn't work.
Maybe you can help me out.
Domoticz has IP 127.0.0.1:8080
When I do the command for 127.0.... it just gives error.
Using Domoticz V3.7017 on Windows 10.
bbqkees
Post by bbqkees »
Is Domoticz running on the same machine as iSpy?
adam0908
Post by adam0908 »
Tnx for this information...some new thing learn...
Marzel
Post by Marzel »
bbqkees wrote:Is Domoticz running on the same machine as iSpy?
I´m sorry I didn´t return here and didn´t answer your question.
I got it running in the meantime.
Thanx for your instructions.
marktn
Post by marktn »
Top instructions! It works.
Verstuurd vanaf mijn HUAWEI GRA-L09 met Tapatalk
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
steffo
Post by steffo »
I have my iSpy and like to control a switch based on motion detecting on a Hikvision camera.
The camera works fine and the alerts are also OK (beep and recording)
I created a virtual switch but could not find the 'motion detector' in type selection.
Is this necessary and how can I get 'motion detection' ?
I tried to just create a swithch and use this url:
http://192.168.1.191:8080/json.htm?type ... itchcmd=On
This does not work - it does not work if i write it into a browser either - I get' Err'
as response..
I hope anyone can help!
bbqkees
Post by bbqkees »
The switch ID is the IDX number of the switch in Domoticz.
This is usually a 3 digit number.
You can look it up via Setup->Devices and then search for the switch.
jth62
Post by jth62 »
Hi bbqkees !
thank you very much for these instructions!
I can launch the following link from a batch :
@echo off
start /b http://192.168.1.100:8080/json.htm?type ... itchcmd=On"
timeout /t 5
TASKKILL /IM chrome.exe /F
But when I try to activate the url call , nothing happens :
Can you confirm that this synthax is correct?
thank you in advance
Best regards
Julien
astrapowerrr
Post by astrapowerrr »
Going to test this... looks
Evelen
Domoticz version: 2.4538
Post by Evelen »
The problem with this is that ispy think lights turning on and off is motion
eeve
Domoticz version: 4.97
Post by eeve »
Marzel wrote: Saturday 29 April 2017 18:48
Hi Marzel,
You got it running, but how?
I have also a problem with Domoticz and Ispy on the same WINDOWS computer. I can't login Domoticz and also the Domoticz App has problems with connecting as long as Ispy runs. If I shutdown Ispy and reboot without automatically starting Ispy on startup, Domoticz logs-in automatically and the app works fine. The port 8080 is connected in the Router and that isn't the problem. How can I tell Domoticz and/or Ispy to use another IP-address then 127.0.0.1?
Domoticz + Ispy @ Windows 10
A wheelchair doesn't end your life;
but it's a challenge to continu
lost
Post by lost »
Evelen wrote: Tuesday 09 January 2018 0:02 The problem with this is that ispy think lights turning on and off is motion
Motion detection results from image pixel variation estimates, so this issue is always there as well on cams embedded motion detection, when used. This can only be mitigated carefully tuning sensitivity/level and selecting motion detection zones less subject to this kind of changes... but not always!
For instancen cams that can switch day/night mode are not very "clever" on this: Usually, you get lots of false captures because the dumb guys who designed the firmware didn't provided the feature to switch motion detection off automatically for a few seconds when switching day/night!
On my side, as I don't want to have continous video flows using bandwidth on my LAN, I only used motion captures to FTP. Some cams (I have an Edimax the provide the feature, another from same manufacturer + other Dlink that do not) provide the ability to trigger an http link on captures that should be able to feed a Domoticz virtual PIR in the same way as iSpy directly from the IP cam.
But as it's quite uncommon, I prefer to rely on a service I wrote that monitors cams FTP subdirs every 10s (to have something still responsive enough & have time to do the in-loop processing) and, if files are found, is able to switch Domoticz associated cam virtual PIR for 10s using json http API.
It's also able to email captures (can be configured to do so only on absence, checking security panel status) in an encrypted archive + do some basic image check (more sophisticated stuff, like running another layer of motion check on camera FTP'ed motion images, would not run in the allocated timeframe on a PI, especially with several cams) to filter out those that are almost black (most of those resulting from day->night switch) for cams that provide the IR cut feature.
As well, most reliable cams on motion detection side are those able to provide separate images (instead of short videos). Don't ask me why, this is what I observed from my devices. They also allow better implementation in a security system as number of images in a time slice can be used as an estimate of motion (idea behind this: A bird passing by will not trigger many images compared to someone attempting to break your door): In a system that use an additive weighting mechanism for, lets's say 1mn time slices, were each sensor is allocated a weight... cam virtual PIRs can set a weight resulting from capture nb.
Idea behind this is an internal sensor have a base weight that immediately triggers the siren, external ones only have a fraction of it (so they must trigger several times or several sensors must trigger in the 1mn slice before cumulative weight reset) to reject false positives.
=> whatever the solution, some amount of post processing will be needed because motion detection is never perfect. Doing so, my advice is to make it per cam configurable as they will all behave differently depending on model and location.
