gizmocuz wrote:Tested the motion sensor... working good here
Make sure you enabled accept new hardware, you should get a new alarm sensor (burglar = 7)
For a explanation of the values see this excellent post, or see the "technical" manual..
Also the switch labeled "sensor" with the ID ending on '00' get's ON for motion, and OFF when there is no motion
Also check your parameters, ( #3 is set to 240 by default, = motion of after 4 minutes of no motion), and command #5 = basic set
And make sure your controller (node 1) is in Group 1 of the multisensor
Thanks ill try that!
accept new hardware was already enabled in the settings.
How do you put the controller in group #1 same with the sensor? Is this ok?
- mesh.png (49.13 KiB) Viewed 7762 times
- mesh2.png (40.21 KiB) Viewed 7762 times
And some logging:
2017-03-20 20:11:25.356 EventSystem: reset all events...
2017-03-20 20:11:25.362 EventSystem: reset all device statuses...
2017-03-20 20:11:25.363 EventSystem: Started
2017-03-20 20:11:25.856 OpenZWave: Starting...
2017-03-20 20:11:25.866 OpenZWave: Version: 1.4-2228-gbce4a88-dirty
2017-03-20 20:11:25.866 OpenZWave: using config in: /home/pi/domoticz/Config/
2017-03-24 10:48:01.447 Error: OpenZWave: Driver Failed!!
2017-03-24 10:48:37.527 Incoming connection from: 192.168.0.4
2017-03-24 10:49:24.452 OpenZWave: Closed
2017-03-24 10:49:25.956 OpenZWave: Starting...
2017-03-24 10:49:25.956 OpenZWave: Version: 1.4-2228-gbce4a88-dirty
2017-03-24 10:49:25.956 OpenZWave: using config in: /home/pi/domoticz/Config/
2017-03-24 10:49:25.961 Error: OpenZWave: Driver Failed!!
2017-03-24 10:49:58.465 OpenZWave: Closed
2017-03-24 10:50:01.978 OpenZWave: Starting...
2017-03-24 10:50:01.978 OpenZWave: Version: 1.4-2228-gbce4a88-dirty
2017-03-24 10:50:01.978 OpenZWave: using config in: /home/pi/domoticz/Config/
2017-03-24 10:50:02.190 OpenZWave: Driver Ready
2017-03-24 10:50:02.213 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2017-03-24 10:50:02.213 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
2017-03-24 10:50:02.213 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Luminance, Instance: 3
2017-03-24 10:50:02.214 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Relative Humidity, Instance: 5
2017-03-24 10:50:02.214 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Ultraviolet, Instance: 27
2017-03-24 10:50:02.216 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-03-24 10:50:02.216 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-03-24 10:50:02.216 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-03-24 10:50:02.217 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Burglar, Instance: 1
2017-03-24 10:50:02.217 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2017-03-24 10:50:05.051 Error: Webserver: File '/images/General.png': No such file or directory (2)
2017-03-24 10:50:14.771 OpenZWave: All Nodes queried (Some Dead)
2017-03-24 10:50:14.771 OpenZWave: Received Node Dead notification from HomeID: 4149631228, NodeID: 3 (0x03)
2017-03-24 10:51:00.350 OpenZWave: Received timeout notification from HomeID: 4149631228, NodeID: 3 (0x03)
2017-03-24 10:58:29.241 User: Admin initiated a switch command (11/MS-Motion/On)
2017-03-24 10:58:29.241 Error: OpenZWave: Internal Node ValueID not found! NodeID: 3 (0x03), instanceID: 0
