Today I received a smart meter, so its immediately connected to Domoticz. However, I notice that wit RFX, Zwave and P1 (and some more) on 1 Domoticz Pi it is simply not working together. So, I installed a separate Pi for the P1 meter.
But now, when I connect it as a slave to my master Domoticz, it connects, but the meter is never showing up. Is there a way to push the meter from the slave to the master?
P1 Meter on a different Domoticz Server
mschut
- Domoticz version: V3.5613
Re: P1 Meter on a different Domoticz Server
Duh. You have to assign rights to a specific user.
- K3rryBlue
- Domoticz version: V4.10xx
- Setup a new user on the slave device (setup->More Options->Edit Users
- After user is created select -> Set Devices
- Click in the left panel,the devices you need (most likely Gas and Meter) -> Save
- On the master add the remote pi as new hardware ip:xxx.xxx.xxx.xxx:6144
- Items should now appear on the master pi
Domoticz V4.10717, RPi2 -> Linux raspberrypi 4.4.47-v7+ , RFXCOM - RFXtrx433 USB 433.92MHz ,RAZBERRY2 and OpenZWave USB Version: 1.4-2363-g1f10253-dirty
