Mimo2 for Garage Door opener
98ksxj
Post by 98ksxj »
I am using the mimo2 with domoticZ. The device shows up with the following devices. None of witch seem to say if the door is open or closed with a magnetic sensor. The indicator light on the board comes on when the door is open. All the switches control one of the garage doors. I have listed the link to how I wired the board to the doors, but for the mimo2 instead of mimolite since I have two garage doors. Is their a configuration change I need to make to the board itself so I can monitor the sensors?
Alarm Type
Alarm Level
Switch1 - Opens\Closes Door1
Switch2 - Opens\Closes Door1
Switch3 - Opens\Closes Door2
Power Management
Switch4 - Opens\Closes Door1
Switch5 - Opens\Closes Door2
The Door1 is wired too N01\COM1 and the magenetic sensor for Door1 is to SIG1\GND
The Door2 is wired too N02\COM2 and the magenetic sensor for Door2 is to SIG2\GND
https://cdn.discourse.org/smartthings/u ... 51e102.jpg
98ksxj
Re: Mimo2 for Garage Door opener
Post by 98ksxj »
I would also like a different switch type. Looking for a momentary switch instead of an off\on switch.
98ksxj
Post by 98ksxj »
Reply from Fortrezz
It seems that DomoticZ is able to see the 2 relay endpoints, but not the signal inputs. Unfortunately, we are not familiar with this brand and have not tested independently. Typically, the problem we see "in general" is that the Z-wave controller thinks our signal inputs are the same type of endpoint as the relay's. Which they are not. The fix is on their end. They have to change their handler to create different devices for endpoints 1 & 2. I suggest you send them our user manual (downloadable on our website in the support page) and ask them to fix their handling of this device. The user manual will give them the info they need.
anybody know how to change that in Domoticz?
sciroccojc
Post by sciroccojc »
Has anyone been able to get this working? I would love to be able to use the floor mounted door sensors I bought for this setup.
