Harlov wrote:
I've got it working now, I had to put a @ after KEY_PLAYPAUSE@ . I also had to modify the configuration files in it's default setup, the daemon is run as user nobody and i have Changing the user to pi, and then restart and it worked
Are play and pause separate buttons? It would seem that either you've linked them both to this "KEY_PLAYPAUSE@" command or they send the same IR command. You need to distinguish them somehow. The number between means:
Nautilus wrote:Are play and pause separate buttons? It would seem that either you've linked them both to this "KEY_PLAYPAUSE@" command or they send the same IR command. You need to distinguish them somehow. The number between means:
thd --dump /dev/input/event*
When i press play button
EV_KEY KEY_PLAYPAUSE 1 /dev/input/event0
# KEY_PLAYPAUSE 1 command
EV_KEY KEY_PLAYPAUSE 0 /dev/input/event0
# KEY_PLAYPAUSE 0 command
and i press pause button
It is the same function in both play and pause,
It works when I use Toggle, but then I can turn on and off on the same button, the idea was that it should be off when I press play,
and on when I press the pause button it may not be possible, otherwise, it works with Toggle
You are using a Harmony remote? Then you can decide which IR command play sends and which IR command pause sends. Make sure they are not the same. After this, using the Flirc configuration program you can link the IR command from "play" to a certain key (combination) and the IR command from "pause" to another key (combination).
With this kind of configuration you see a different event in the dump output when you press each button (play / pause) and can map them to Domoticz On and Off commands respectively.
Nautilus wrote:You are using a Harmony remote? Then you can decide which IR command play sends and which IR command pause sends. Make sure they are not the same. After this, using the Flirc configuration program you can link the IR command from "play" to a certain key (combination) and the IR command from "pause" to another key (combination).
Yes, I got it to work exactly how I wanted it thanks again. The next step is that I wish to have a feature that gradually lowers the light when I press play or pause with a dimmer, you might be wondering what I should have this for, it's for my home cinema I have in the basement. I have to think a little bit with dimmer what to do.
yes I have a Harmony remote 650. I'll check on what I can do with it
Thank you very much for your help, it's appreciated
OK, great!
Harlov wrote:The next step is that I wish to have a feature that gradually lowers the light when I press play or pause with a dimmer
As long as the dimmer is controlled by Domoticz, you can create a Lua script (or maybe even a Blockly) that reacts to the switch change and starts a separate dimming script. But this script, even though it can be based on e.g. json calls to Domoticz, should be something that runs outside Domoticz if you want it to take more than a couple of seconds as Domoticz will wait for any scripts to finish before proceeding (a long running script within Domoticz will hang it)...
