Hi.
I'm having a bit of a hard time to understand what so special with port 443 and HTTPS. Once I have opened the port, i can still access my domoticz if I know Username and password, and if anyone else have gotten that they would to the same way on HTTP.
So I dont actually get whats so safe about it? (or did i completely missunderstand?)
How can I access domoticz safely from outside my LAN?
I googled this and ended up installing openVPN with "piVPN" on the same raspberry pi domoticz is running on, but have no idea how to run domoticz through "openvpn" or if I missunderstood that too.
Anyone know more about this? or can point me to a link/previous post explaining this?
John
domoticz on raspberry pi safety with https.
Re: domoticz on raspberry pi safety with https.
I might be able to answer the openvpn question.
I run openvpn on my router, and openvpnconnect on my phone.
After I set up openvpn on my phone, I can make a openvpn connection when I am away.
Once you have the openvpn connection, you can access your network just like you were at home.
So if you have a domoticz client on your phone that lets you control domoticz, after you open the connection, you can open and use the domoticz client just like you were at home.
The openvpn connection should allow your phone to do the same things you can do while at home.
Randy
Randy
Ugh ofcourse. I can use the OpenVPN to connect to my LAN, then connect to the domoticz from there. I just felt really stupidrandytsuch wrote:I might be able to answer the openvpn question.
Randy
Just need to connect my phone to the openvpn program running on the pie, then voila
- Domoticz version: 3.5877
HTTPS means that your connection to Domoticz is encrypted - it's not about protecting the service itself from hackers - it's about protecting your connection to it - for example if you sit at McDonalds connected to the free WiFi and you open the Domoticz app on your phone and connect to your Domoticz instance over standard HTTP - then your username and password (and cookies) can be intercepted by anyone else connected to the McDonalds network.
For almost everything - you really would be better suited to using a VPN and using it whenever you are connected to a public WiFi network (not just free ones, pay ones too - the problem still exists on hotel networks etc - any WiFi network where other people who you don't know can connect).
AEOTEC ZStick, 11 ZWave Nodes, RFXCOMM, 50ish Byron Sockets.. HE851 (PIR), 2x HE852 (DoorContact)
WS2300, CM180, CC128, 2xTHGR122NX, 2xPiZeroW w/DS18B20, 8Ch 1W Relay Board.
8 Panasonic IP Cams, 1 16ch CCTV DVR + 15 CCTV Cams
I had the same question when I started using VPN.
So after I make a connection, then what?
Its easy once you know the answer, like so many things
- Domoticz version: 2022.2
When configured correctly everything works the same as when you are at home. Just connect to the same ip addresses. But this depends on the configuration of your vpn
