I've just started to use Domoticz. Devices for rain and wind is not created. The devices are from Oregon WMR200 and are collected via Tellstick. I've been using version 5745 and just upgraded to 5838.
The readings is found and decoded, but a sensor is not created. What do I need to do to create the devices?
I've got four temperature/humidity sensors and they are working, both from Oregon and other.
Based on the log (see below), it looks like the data is recieved and decoded right.
Oregon, Wind meter, no sensor created
2016-10-30 17:43:21.056 Tellstick: rawDeviceEvent 1: class:sensor;protocol:oregon;model:1984;id:17;winddirection:337.5;windaverage:0.0;windgust:0.0;
2016-10-30 17:43:21.056 Tellstick: sensorEvent 17,oregon,1984,16,337.5
2016-10-30 17:43:21.056 Tellstick: sensorEvent 17,oregon,1984,32,0.0
2016-10-30 17:43:21.056 Tellstick: sensorEvent 17,oregon,1984,64,0.0
2016-10-30 17:44:35.770 Tellstick: rawDeviceEvent 1: class:sensor;protocol:oregon;model:2914;id:15;raintotal:767.8;rainrate:0.0;
2016-10-30 17:44:35.770 Tellstick: sensorEvent 15,oregon,2914,4,0.0
2016-10-30 17:44:35.770 Tellstick: sensorEvent 15,oregon,2914,8,767.8
2016-10-30 17:43:42.336 Tellstick: rawDeviceEvent 1: class:sensor;protocol:oregon;model:F824;id:10;temp:5.3;humidity:74;
2016-10-30 17:43:42.336 Tellstick: sensorEvent 10,oregon,F824,1,5.3
2016-10-30 17:43:42.336 Tellstick: sensorEvent 10,oregon,F824,2,74
2016-10-30 17:43:43.504 Tellstick: rawDeviceEvent 1: class:sensor;protocol:oregon;model:F824;id:12;temp:5.6;humidity:65;
2016-10-30 17:43:43.504 Tellstick: sensorEvent 12,oregon,F824,1,5.6
2016-10-30 17:43:43.504 Tellstick: sensorEvent 12,oregon,F824,2,65
2016-10-30 17:43:42.544 Tellstick: rawDeviceEvent 1: class:sensor;protocol:fineoffset;id:135;model:temperaturehumidity;humidity:64;temp:9.8;
2016-10-30 17:43:42.544 Tellstick: sensorEvent 135,fineoffset,temperaturehumidity,1,9.8
2016-10-30 17:43:42.544 Tellstick: sensorEvent 135,fineoffset,temperaturehumidity,2,64
2016-10-30 17:44:05.351 Tellstick: rawDeviceEvent 1: class:sensor;protocol:mandolyn;id:11;model:temperaturehumidity;temp:22.3;humidity:55;
2016-10-30 17:44:05.351 Tellstick: sensorEvent 11,mandolyn,temperaturehumidity,1,22.3
2016-10-30 17:44:05.351 Tellstick: sensorEvent 11,mandolyn,temperaturehumidity,2,55
