Fibaro Double Switch FGS-223 only switches with physical toggle switch
I have several Fibaro z-wave devices around the house in combination with Domoticz on a RPi3. The majority is installed with a momentary switch in combination with a dimmer module.
My issue is that I cannot switch S1 with Domoticz, only with the (single) toggle switch. S2 can be switched with Domoticz, but I have no physical switch attached to Q2/S2. Parameter 20 is on '2', I have also tried '1'.
Does anyone know if I have to set another parameter to enable the switching from within Domoticz??
Many thanks!
Many thanks!
Re: Fibaro Double Switch FGS-223 only switches with physical toggle switch
reboot your domoticz server and it wil work. Had the same issue
Worked! Many thanks!!
- Domoticz version: 3.6334
It works for me very well too. Many thanks!!
- berny
I spend hours to resolve this problem after include FGS-223
S1(switch on/off) / Q1(on/off) => OK
S2(switch on/off) / Q2(on/off) => OK
via domoticz:
S1(domoticz on/off) / Q1(on/off) => NOT OK!!!
S2(domoticz on/off) / Q2(on/off) => OK
when I have read this subject and
I have REBOOT my Raspberry => everything OK!!!
Thanks for this hint.
But why ??
via domoticz:
But why ??
Also worked for me! Thanks a lot for this hint!
Domoticz on RPi3 with Aeontec Z-Stick gen5. Beta.
Z-Wave, Zigbee, WiFi and MQTT (mainly Tasmota), Neo Cool Cam, Devolo, Fibaro, Shelly, Hue, Osram, Blitzwolf, TP-Link, Alexa. Latest: Somfy IO integration
- robpow
- Domoticz version: Beta :)
Can’t believe it was that easy! Had the exact same problem.
Matt
Matt
I have the same problem Q1 does not change state with domoticz. in windows it does not work restarting the system. Any solution please?
This worked for me also!
Edit ... Below also solved after next reboot next day
Almost......
Now both the Switches work again within Domoticz but still only one will react from my Homekit
In the beginning the S1 did not react by Domoticz and not by the app (S2 works perfectly)
But now S1 works from Domoticz but domoticz still does not react on Homekit(homebridge) push button
I have all the parameters the same between S1 and S2.
Anybody an idea, or how to see if homebridge actualy sends a signal to Domoticz?
Almost......
Rebooting via shell script worked for me too on Ubuntu.
in windows no found...
- Domoticz version: V4.10717
Thanks, you save my day!!
