Hello , If anyone could help me I would be very grateful.
I have domoticz installed on windows 10. The latest beta.
I would like to access my domoticz , through a browser on a different computer, within my local network.
I can not figure out how to configure it. The current setting is the default setting. 127.0.0.1:8080
I've also tried to access the server with the ios app on the ipad, Pilot.
No satisfactory result.
Thank you very much
Home lan access Help!! Topic is solved
- Domoticz version: 2020.2
Re: Home lan access Help!!
you have to use the ip of the pc where domoticz is installed.
127.0.0.1 is loopback device, reachable only by the same machine.
On the windows machine where domoticz is installed:
-Start..run..cmd
-In the black window type: ipconfig
-Get the ip address of your lan connection
Use it in your browser instead of 127.0.0.1 (es. http://192.168.1.100:8080 )
-Start..run..cmd
Ubuntu 20.04 on ACEPC AK1 (previously RPi3b+)
Z-Stick Gen5, RFXtrx433E, Philips HUE Bridge, Yeelight, ESP8266 NodeMCU, Broadlink RM
dZvents, bash, php, Node-RED
It works perfect, in the browser and in the ipad app.
Thanks Kubrik
Thanks Kubrik
