Adjustment for humidity values
janegils
Post by janegils »
I can see that when you click on 'edit' for a temp/humidity sensor you can enter an adjustment for the temperature readings.
But there seems to be not possible to enter adjustments for the humidity value, which would be even more useful since humidity sensors tend to be rather inaccurate.
A precision of +/-5% is fairly common.
As an example: I have two Esic temp/hum. sensors on my table now, and the temp. readings are identical, but the humidity values have a 9% difference.
Would others like to see this implemented?
Running Domoticz on Ubuntu Linux server
RFXCOM_Transceiver
Aeon Labs Z-Stick S2
elythomaslumber
Domoticz version: 2023.1
Re: Adjustment for humidity values
Post by elythomaslumber »
9% is a big difference; but is the difference linear meaning always 9%?
Makes only sense to have an offset if the difference is always the same.
Hardy
janegils
Post by janegils »
Well, with som testing one can find the average offset, and at least get closer to the truth...
RFXCOM_Transceiver
marin849
Domoticz version: 2.4xxx
Post by marin849 »
There are usually both an ofset and a scaling error!
I have just compared 15 sensors against each other. Tested sensors are the quite common Proove TSS320,Viking 02812. Both are using the Viking 2035/2038 protocol. Also 4 Viking temperature only sensors.
All of them are within +-0,5C for temperatures between 0-20C, and with ofset correction this is reduced to +-0.2. With linear correction its perfect. Of course it should be calibrated over a bigger interval than I did.
The humidity varies more: +-5% uncorrected. This is a lot since it means that one sensor can show 65% and another 75% which could be critical when monitoring or controlling humidity for corrosion or mold growth. With ofset corretion it is about +-3% and with linear about +-1,2%. The middle humidity point does look strange, maybe I had to short settling time on that one...
So with these observations linear correction would be really nice, especially for humidity!
ThinkPad
Post by ThinkPad »
I would also like to see this.
I have a Z-Wave sensor with combined temperature and humidity status, i can correct the temperature, but not the humidity (which is about 10% off from two other sensors).
sharif
Domoticz version: 3.5574
Post by sharif »
Is this feature on the roadmap?
I got few sensors which are showing about 7% more humidity and I would like to adjust this value/offset.
Only thing I can adjust at the moment is temperature (as already stated)
michib
Domoticz version: 3.5877
Post by michib »
+1 for the correction feature for humidity values.
kubrik
Post by kubrik »
+1
Ubuntu 20.04 on ACEPC AK1 (previously RPi3b+)
Z-Stick Gen5, RFXtrx433E, Philips HUE Bridge, Yeelight, ESP8266 NodeMCU, Broadlink RM
dZvents, bash, php, Node-RED
mayyam
Domoticz version: 4.11333
Post by mayyam »
+1
____
may
_______________
- Dell FX-160 / Ubuntu 16.04
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
StratosHF
Domoticz version: 2025.1
Post by StratosHF »
+1
zhoblom
Post by zhoblom »
Yeah, that would be a tremendously helpful feature. It's ironic that temperature sensors that are nowadays pretty accurate can be offset-calibrated, but humidity ones can not.
Interestingly, there is provision in the code to do that. There is already AddjValue and AddjMulti for temperature, but similar block for humidity (using AddjValue2 and AddjMulti2 columns from DeviceStatus table) is there, but disabled:
        AddjValue=0.0f;
        AddjMulti=1.0f;
        m_sql.GetAddjustment2(HwdID, ID.c_str(),Unit,devType,subType,AddjValue,AddjMulti);
        Humidity+=int(AddjValue);
        if (Humidity>100)
                Humidity=100;
        if (Humidity<0)
                Humidity=0;
It seems to me that at least for experimentation purposes and for local builds uncommenting this block and then just populating correct AddjValue2 and AddjMulti2 for a specific device in the DeviceStatus table (using sqlite3 command line utility for example) will suffice.
Also note that DB schema allows for two-point calibration, not just one offset, as in the GUI. So with a few extra lines of code one can get even better results than just offsetting humidity by a fixed offset.
Of course, adding GUI support would be some extra work on top.
pa3gmi
Domoticz version: 4.9700
Post by pa3gmi »
Also would like this option.
mpx2
Domoticz version: 4.10717
Post by mpx2 »
I think that setting two reference points like 11 % and 75 % with offsets is enough.
[video]https://www.youtube.com/watch?v=AGycwfeHH_k[/video]
tvurce
Post by tvurce »
+1 for humidity offset
Specialy Bosh BME280 is popular, but crap... 25 % deviation no problem :(
JanAtHome
Domoticz version: 38153
Post by JanAtHome »
sperate
Post by sperate »
+2 for humidity offset :D
GJKNL
Post by GJKNL »
+1
magoafono
Post by magoafono »
+1 for humidity offset!
