Plugin Denon AVR-X2100W Topic is solved
- Dnpwwo
Re: Plugin Denon AVR-X2100W
@l00pz,
@oohlaf reported the -273.1499 bug in Domoticz (not the plugin) and suggested a fix, a pull request is waiting to be merged.
Can you give the next beta version a go and I will have another look at the plugin if it still doesn't work.
- gielie
- Domoticz version: latest β
I tried the new beta but still no luck with the volume.
And neither with the input selector
Another error in the script
2017-02-21 16:21:24.073 User: Machiel initiated a switch command (301/Denon AVR X-2100 - Main Volume/Set Level)
2017-02-21 16:21:24.079 (Denon AVR X-2100) Calling message handler 'onCommand'.
2017-02-21 16:21:24.080 (Denon AVR X-2100) onCommand called for Unit 3: Parameter 'Set Level', Level: -273.1499938964844
2017-02-21 16:21:24.080 (Denon AVR X-2100) Sending data: 'MV-273.1499938964844 '.
2017-02-21 16:22:36.185 User: Machiel initiated a switch command (300/Denon AVR X-2100 - Main Zone/Set Level)
2017-02-21 16:22:36.222 (Denon AVR X-2100) Calling message handler 'onCommand'.
2017-02-21 16:22:36.223 (Denon AVR X-2100) onCommand called for Unit 2: Parameter 'Set Level', Level: -273.1499938964844
2017-02-21 16:22:36.223 Error: (Denon AVR X-2100) 'onCommand' failed 'KeyError'.
2017-02-21 16:22:36.223 Error: (Denon AVR X-2100) ----> Line 213 in /home/pi/domoticz/plugins/Denon/plugin.py, function onCommand
2017-02-21 16:37:17.202 User: Machiel initiated a switch command (300/Denon AVR X-2100 - Main Zone/Set Level)
2017-02-21 16:37:17.247 (Denon AVR X-2100) Calling message handler 'onCommand'.
2017-02-21 16:37:17.247 (Denon AVR X-2100) onCommand called for Unit 2: Parameter 'Set Level', Level: -273.1499938964844
2017-02-21 16:37:17.248 Error: (Denon AVR X-2100) 'onCommand' failed 'KeyError'.
2017-02-21 16:37:17.248 Error: (Denon AVR X-2100) ----> Line 213 in /home/pi/domoticz/plugins/Denon/plugin.py, function onCommand
2017-02-21 16:37:18.450 (Denon AVR X-2100) Calling message handler 'onHeartbeat'.
2017-02-21 16:37:18.451 (Denon AVR X-2100) onHeartbeat: lastMessage PW, Sending 'ZM'.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
@gielie The latest Pull Request hasn't been merged yet, so we need to wait for this.
- gielie
Oh haha, ill wait.
- FIBARO FGS223
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
@Dnwwwo the Plugin seems to be working now in the latest commit! Thanks
- gielie
I updated to the latest beta and its working, yeah, tanks.
There is only 1 inconvenience, when I turn on the main device, zone 2 turns on. And when I turn off the main device, zone 2 won't turn off. I have to manually turn off zone 2.
I created a script when main zone is off turn zone 2 off.
Is there a better solution?
- FIBARO FGS223
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
- Domoticz version: V4.10232
I can confirm the same, briliant !l00pz wrote:@Dnwwwo the Plugin seems to be working now in the latest commit! Thanks
Any plans to add Surround Modes into a Selector switch too? I'm not up to speed on python, but it would seems possible to do this same way as the Source Input selector.
Have this plugin running on a Marantz NR1602 without flaws now. Previously had a lot of LUA and xml parsing done to get this same result.
Great work ! Save me a bunch.
Ray
- Dnpwwo
@gielie,
Although my amp has 3 zones I only use 1. I just added the other code in there to show what could be done. I've had a look at the code and there is nothing obvious so you will need to post a log with debug turned on to help me spot the problem.
I thought I was treating the zones as separate so the amp shouldn't turn off until all zones are turned off (which seems to line up with what you are seeing) but if the power is off and a command is recieved, I send Power On which I thought would restore it to the last state. This works for one zone but maybe not multi-zone.
Perhaps I should try sending the specific zone on command not Power On to see if that works better. The manual is rubbish unfortunately so I'll need to play a bit.
@raymond,
Didn't realise this would work on Marantz as well. Happy days !
Is that set per zone or just at the amp level? There is no reason it wouldn't work
@raymond,
Yes works on Marantz also
. The protocol and Parameter list is exactly the same, though SOURCE names are different, but that is also true for different Denon models I believe.
The Selector Switch for SOURCES and the SI command work the same way on my Marantz NR1602, same goes for MV, PW and ZM/Z2 commands.
Selecting the surround mode would work like the SOURCE INPUT you already have implemented. Creating another Selector Switch like the SOURCE INPUT but with different names (DOLBY, DTS, STEREO, AUTO etc.) would do the trick, along with the MS command sent instead of SI (Page 12 and 29 of the protocol.pdf shared earlier)
I'm happy as is, but if you're looking to implement more features, this would be on my list. I've seen folks getting into the PS command which handles all equalizer stuff, but that wouldn't have my initial interest.
Cheers,
Ray
Cheers,
Ray
- G3rard
- Target OS: -
- Domoticz version: No
I am using the script for my Marantz NR1604 and it all seems to work.
I only get the error messages in the log like: Unknown message '@P' ignored. See the detailled log below.
I am using the latest beta v3.6807 and updated the Sources field with the right sources from my Marantz (copied the names from the web gui of the Marantz).
Any ideas how to fix this? Or is this something specific for the Marantz?
2017-02-28 22:54:12.908 (Marantz) onMessage called with Data: '@PWR:1'
2017-02-28 22:54:12.908 Error: (Marantz) Unknown message '@P' ignored.
2017-02-28 22:54:22.324 (Marantz) Calling message handler 'onHeartbeat'.
2017-02-28 22:54:22.324 (Marantz) onHeartbeat: lastMessage PW, Sending 'ZM'.
2017-02-28 22:54:22.324 (Marantz) Sending data: 'ZM? '.
2017-02-28 22:54:22.375 (Marantz) Calling message handler 'onMessage'.
2017-02-28 22:54:22.375 (Marantz) onMessage called with Data: 'ZMOFF'
2017-02-28 22:54:22.375 (Marantz) onMessage called with Data: '@PWR:1'
2017-02-28 22:54:22.375 Error: (Marantz) Unknown message '@P' ignored.
2017-02-28 22:54:32.359 (Marantz) Calling message handler 'onHeartbeat'.
2017-02-28 22:54:32.359 (Marantz) onHeartbeat: lastMessage ZM, Sending 'SI'.
2017-02-28 22:54:32.359 (Marantz) Sending data: 'SI? '.
2017-02-28 22:54:32.427 (Marantz) Calling message handler 'onMessage'.
2017-02-28 22:54:32.427 (Marantz) onMessage called with Data: 'SITV'
2017-02-28 22:54:32.427 (Marantz) onMessage called with Data: '@SRC:11'
2017-02-28 22:54:32.427 Error: (Marantz) Unknown message '@S' ignored.
2017-02-28 22:54:32.427 (Marantz) onMessage called with Data: 'PSMDAX OFF'
2017-02-28 22:54:32.477 (Marantz) Calling message handler 'onMessage'.
2017-02-28 22:54:32.477 (Marantz) onMessage called with Data: '@MDA:1'
2017-02-28 22:54:32.477 Error: (Marantz) Unknown message '@M' ignored.
2017-02-28 22:54:32.527 (Marantz) Calling message handler 'onMessage'.
2017-02-28 22:54:32.527 (Marantz) onMessage called with Data: 'SVOFF'
2017-02-28 22:54:42.344 (Marantz) Calling message handler 'onHeartbeat'.
2017-02-28 22:54:42.344 (Marantz) onHeartbeat: lastMessage SI, Sending 'MV'.
2017-02-28 22:54:42.344 (Marantz) Sending data: 'MV? '.
2017-02-28 22:54:42.394 (Marantz) Calling message handler 'onMessage'.
2017-02-28 22:54:42.394 (Marantz) onMessage called with Data: 'MV56'
2017-02-28 22:54:42.394 (Marantz) onMessage called with Data: '@VOL:-240'
2017-02-28 22:54:42.394 Error: (Marantz) Unknown message '@V' ignored.
2017-02-28 22:54:42.462 (Marantz) Calling message handler 'onMessage'.
2017-02-28 22:54:42.462 (Marantz) onMessage called with Data: 'MVMAX 97'
2017-02-28 22:54:42.462 (Marantz) Unknown: Action MV, Detail 'MAX 97' ignored.
2017-02-28 22:54:52.329 (Marantz) Calling message handler 'onHeartbeat'.
2017-02-28 22:54:52.329 (Marantz) onHeartbeat: lastMessage MV, Sending 'MU'.
2017-02-28 22:54:52.329 (Marantz) Sending data: 'MU? '.
2017-02-28 22:54:52.379 (Marantz) Calling message handler 'onMessage'.
2017-02-28 22:54:52.379 (Marantz) onMessage called with Data: 'MUOFF'
2017-02-28 22:54:52.379 (Marantz) onMessage called with Data: '@AMT:1'
2017-02-28 22:54:52.379 Error: (Marantz) Unknown message '@A' ignored.
2017-02-28 22:55:02.361 (Marantz) Calling message handler 'onHeartbeat'.
2017-02-28 22:55:02.361 (Marantz) onHeartbeat: lastMessage MU, Sending 'PW'.
2017-02-28 22:55:02.361 (Marantz) Sending data: 'PW? '.
2017-02-28 22:55:02.428 (Marantz) Calling message handler 'onMessage'.
2017-02-28 22:55:02.428 (Marantz) onMessage called with Data: 'PWSTANDBY'
2017-02-28 22:55:02.428 (Marantz) onMessage called with Data: '@PWR:1'
2017-02-28 22:55:02.428 Error: (Marantz) Unknown message '@P' ignored.
Not using Domoticz anymore
I have the same thing on my NR1602 indeed. I do not know if I did something wrong or if it's just the Marantz. Everything else works flawless.G3rard wrote:I am using the script for my Marantz NR1604 and it all seems to work.
Ray
- Dnpwwo
@raymond & @G3rard,
The plugin will be fine because this is just the warning when it sees something unexpected and isn't in 'ignoreMessages' on line 57.
Given that it appears more amps than I expected can use this maybe 'ignoreMessages' should be a parameter. I'm a little tied up on something else at the moment and can look at it in a few days maybe.
I don't mind the message, it clogs up the log a bit, but all works fine!
Ray
Ray
- G3rard
- Target OS: -
@Dnpwwo, I have added @P|@M|@S|@V|@A to the ignoreMessages in the plugin and then it's working fine
Also tried to add that field to the parameters by adding
and on line 57
but that gives a NameError in the log.
Can you point me in the right direction (sorry no Python knowledge yet...).
<param field="Ignore" label="Ignore Messages" width="550px" required="true" default="|SS|SV|SD|MS|PS|CV|@P|@M|@S|@V|@A|"/>
ignoreMessages = str(Parameters["Ignore"])
2017-03-09 00:27:48.637 Error: (Denon4306) failed to load 'plugin.py', Python Path used was '/home/gerard/domoticz/plugins/Denon/:/usr/lib/python3.4/:/usr/lib/python3.4/plat-x86_64-linux-gnu:/usr/lib/python3.4/lib-dynload'.
2017-03-09 00:27:48.637 Error: (Marantz) Module Import failed, exception: 'NameError'
- Dnpwwo
@G3rard,
The field name needs to be one that Domoticz knows about. Have a look at http://www.domoticz.com/wiki/Developing ... Definition for the list of valid values.
I'm working on another version and was going to do a simpler fix which was to make it just log the message when debugging was turned on (which is probably when it is more useful than the current one)
- G3rard
- Target OS: -
Thanks, didn't read that part of the wiki indeed...
However after changing the name to Mode4 or Mode5 I still get the same error
I will just wait for your new version.
- Dnpwwo
@G3rard,
You need to do the assignment inside onStart (or any other callback). When Python imports a file it also executes it so everything outside a function is evaluated (standard behaviour I can't stop it) but the Domoticz values have not been set up at that point so the Parameters dictionary does not exist (hence the NameError)
Just initialise it to "" on line 57 and then update it in a callback.
- G3rard
- Target OS: -
@Dnpwwo,
Thanks, I added the ignoreMessages to onStart and then it works.
However when I click on Update in the Hardware tab I get the following error.
This is my plugin.py code.
2017-03-11 23:42:59.671 Error: PluginList: Error 'Error document empty.' at line 0 column 0 in XML ''.
2017-03-11 23:43:02.699 (Marantz) Exiting work loop...
2017-03-11 23:43:02.700 Error: Plugin: Async Read Exception: 125, Operation canceled
2017-03-11 23:43:02.701 (Marantz) Denon device has disconnected.
2017-03-11 23:43:02.783 (Marantz) Stopped.
2017-03-11 23:43:02.845 (Marantz) Initialized version 2.2.0, author 'dnpwwo'
2017-03-11 23:43:02.896 (Marantz) Connected successfully to: 192.168.1.138:23
- Spoiler: show
- Dnpwwo
@G3rard,
The "Async Read Exception: 125, Operation canceled" is nothing to worry about, Unix seems to throw that during a plugin forced shutdown sometimes but it isn't a problem.
I haven't seen the "PluginList: Error 'Error document empty.' at line 0 column 0 in XML'." error. How many plugins do you have on your system? Is it just the one?
- G3rard
- Target OS: -
@Dnpwwo,
I have some other plugins on the system (Sonos, Kodi, Rain prediction (Buienradar)).
The pluginlist error appeared for the first time after I changed the Denon script regarding the ignoredMessages.
Users browsing this forum: assp22 and 1 guest
