possibility to start script when switch is pushed
JacquesMulders
Post by JacquesMulders »
does someone know if it is possible to start a script when a switch is pushed, with a variable in the end (just like the evohome hardware)
for example:
dimmer slider is set to 60% "script://dimmer.sh" 60 is started.
another example from the evohome hardware:
script:///usr/local/bin/settemp.sh {deviceid} {mode} {setpoint} {until}
so is it possible for switch/dimmer hardware to send e.g. level, data, idx
script:///home/pi/dimmer.sh {level} {data} {idx}
jvdz
Domoticz version: 4.107
Re: possibility to start script when switch is pushed
Post by jvdz »
Don't think this is possible in the On/Off action script option, but you can do this with a LUA event script which then shells the bash file.
Jos
JacquesMulders
thats not really the action that i want, i can call the api call to get al the data, but it would be much cleaner to just get the variables with the script start.
for the record, ive tryed:
script:///home/pi/dimmer.sh $Level $Data $idx
script:///home/pi/dimmer.sh $level $data $idx
the last 2 where as the json output would be if you retrieve the switch status
jannl
Domoticz version: 2025.5.x
Post by jannl »
If you do this via an eventscript in lua, you get almost what you want I think.
