[solved] List of device type and subtype IDs Topic is solved
getSurreal
I'm looking for a reference where I can find all the device Type and Subtype IDs. Anyone know where I can find it?
Last edited by getSurreal on Thursday 09 March 2017 21:48, edited 1 time in total.
SweetPants
Re: List of device type and subtype IDs
Maybe in the database Table: devicestatus. You can access it with a Sqlite database manager.
getSurreal
I guess I should have mentioned that I already looked there. It only shows devices that already exist, which was helpful for some, but I'd like to see the list of all available options. I figure since the full mapping list doesn't appear to be in the database, it must be in the code somewhere, but I couldn't find it.
getSurreal
Mat2Vence
- Domoticz version: 3.7449
Note that clear to me...
Looks lke we must find type, subtype and swtichtype... what does it correspond to in the .h file? I made some trials but I did not get what I was expected. And what about the "Image" parameter?
jaaap
Re: [solved] List of device type and subtype IDs
I found that if you use the source code (https://github.com/domoticz/domoticz/bl ... aretypes.h) and copy the heximal number and google it, you'll find the decimal number, which you can insert in your code. At least in my case. Haven't tried to use the heximal number in the code. Maybe that also works.
