Paragraph mark symbol in json url
EdwinK
Post by EdwinK »
I have created a switch that should control the various scenes from my Hue.
When I select one of them, it doesn't seem to work, so i checked the log, and noticed that a ¶ symbool has been added into the URL. But where I had put the URL it isn't there.
2017-03-06 14:01:59.564 Error: Error opening url: http://192.168.0.20:8084/json.htm?type= ... tchcmd=Off
The URL in the input-field is:
At first I thought it was a problem with the '&' in the URL, so I changed that to '&' but that didn't do the trick.
What could be the problem?
Running Domoticz on a Synology NAS.
philchillbill
Re: Paragraph mark symbol in json url
Post by philchillbill »
What text editor are you using? There could be a character there that a particular editor is not showing - this often happens when you copy/paste code snippets from web pages. Delete a few characters before and after that strange paragraph mark and re-type the text normally by hand to see if that helps.
Alexa skills author: EvoControl, Statereport, MediaServer, LMS-lite
EdwinK
Post by EdwinK »
Just using the text-editor build-in Domoticz.
I will try your advice. normally I just do a copy all and then cmd-C and cmd-V to paste it in the text-editor.
Nautilus
Post by Nautilus »
EdKo66 wrote:Just using the text-editor build-in Domoticz.
This is a known issue, have seen it in my setup as well. If you search the forum for "paragraph" you get a few links with hopefully a solution for you as well.
E.g. viewtopic.php?f=23&t=13412&p=96906&hili ... son#p96906
viewtopic.php?f=61&t=11195&p=80354&hili ... son#p80354
EdwinK
Post by EdwinK »
Thanks. Will look at those topics. :)
