Buienradar Weather Lookup Plugin
schulpr
Re: Buienradar Weather Lookup Plugin
Hi ffes,
I hope you can find some time to implement the other available weather data soon. I think it's very stable.
<zichtmeters>39000</zichtmeters>
<windstotenMS>13.8</windstotenMS>
<zonintensiteitWM2>292</zonintensiteitWM2>
Thanks for all your work!
Rob
Rob
ffes
@sander815
And when it stops working, what is shown in the log? Do you see the plugin's log lines appear?
ffes
I just released a new version of my Buienradar plugin. This uses the new Settings dictionary that was added to the Python plugin in recent betas. So before you upgrade to this version of the Buienradar plugin be sure to have the latest beta of Domoticz.
So for new users there is zero configuration to get the plugin running initially.
Bengelen
It works for me now, is it hard or possible to get data from buienradar.be also?
ffes
That seems not possible. I use http://xml.buienradar.nl to get the weather information. http://xml.buienradar.be doesn't work, so there is no data to use for me.Bengelen wrote:Is it hard or possible to get data from buienradar.be also?
Also notice that things they provide on http://www.buienradar.be/overbuienradar ... uw-website is much smaller then http://www.buienradar.nl/overbuienradar ... uw-website. Maybe multiple requests from various Belgian users will help them to bring those features to Belgium as well.
RayAmsterdam
Beta 3.6863
Rpi 3b
Today I installed the plugin. After selecting it in the hardware menu, it said the devices are added to the devices tab. Unfortunately they aren't. Am I missing something?
Rpi 3b
- EdwinK
- Domoticz version: BETA
When trying to restart domoticz I get the following
Running on Synology 6.1
Stopping and restarting from Synology panel didn't help eitherroot@DiskStation:/volume3/@appstore/domoticz/plugins/buienrader# sudo service domoticz.sh restart
sudo: service: command not found
ffes
What do you see in the log? Did you try to filter the devices based on the name you gave on the hardware page?RayAmsterdam wrote:Today I installed the plugin. After selecting it in the hardware menu, it said the devices are added to the devices tab. Unfortunately they aren't. Am I missing something?
RayAmsterdam
I get error "Error: Buienradar hardware (21) thread seems to have ended unexpectedly" in the log. I used the filter.ffes wrote:What do you see in the log? Did you try to filter the devices based on the name you gave on the hardware page?RayAmsterdam wrote:Today I installed the plugin. After selecting it in the hardware menu, it said the devices are added to the devices tab. Unfortunately they aren't. Am I missing something?
ffes
Pfff, I have never seen that before. I don't think it is something I can do much about. A script should not be able to end a thread that way, I would think.RayAmsterdam wrote:I get error "Error: Buienradar hardware (21) thread seems to have ended unexpectedly" in the log. I used the filter.
Do you run the latest beta of domoticz? Could you restart domoticz and look at the logs?
RayAmsterdam
Yep, running latest beta. Already restarted Domoticz and pi. Sonos plugin is running normal.ffes wrote:Pfff, I have never seen that before. I don't think it is something I can do much about. A script should not be able to end a thread that way, I would think.RayAmsterdam wrote:I get error "Error: Buienradar hardware (21) thread seems to have ended unexpectedly" in the log. I used the filter.
RayAmsterdam
I reinstalled the plugin and reconfugured it in Domoticz. It stated again the hardware is created and devices added. I got the following errors in the log:
2017-03-07 20:50:34.186 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Buienradar/:/usr/local/lib/python35.zip:/usr/local/lib/python3.5/:/usr/local/lib/python3.5/plat-linux:/usr/local/lib/python3.5/lib-dynload'.
2017-03-07 20:50:34.186 Error: (Buienradar) Module Import failed, exception: 'ImportError'
2017-03-07 20:50:34.186 Error: (Buienradar) Module Import failed: ' Name: buienradar'-
Snowtiger
- Domoticz version: 4.10915
there is a problem with the library the plugin uses - in your error code you see /plugins/Buienradar - if you do aRayAmsterdam wrote:I reinstalled the plugin and reconfugured it in Domoticz. It stated again the hardware is created and devices added. I got the following errors in the log:Code: Select all
2017-03-07 20:50:34.186 Error: (Buienradar) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Buienradar/:/usr/local/lib/python35.zip:/usr/local/lib/python3.5/:/usr/local/lib/python3.5/plat-linux:/usr/local/lib/python3.5/lib-dynload'. 2017-03-07 20:50:34.186 Error: (Buienradar) Module Import failed, exception: 'ImportError' 2017-03-07 20:50:34.186 Error: (Buienradar) Module Import failed: ' Name: buienradar'
git cloneCode: Select all
1.In your domoticz/plugins directory do
cd domoticz/plugins
git clone https://github.com/ffes/domoticz-buienradar.git
2.Alternatively you can download the latest version from https://github.com/ffes/domoticz-buienradar/archive/master.zip and unzip it. Then create a directory on your Domoticz device in domoticz/plugins named buienradar and transfer all the files to your device.@ffes should update git to get the modules in /plugins/Buienradar to let this work via git - my choice of method btw
I created an issue in Git to address this
Last edited by Snowtiger on Wednesday 08 March 2017 12:48, edited 3 times in total.
RayAmsterdam
Thanks! I missed the files.
Derik
mmm
Is there a how to for plugins?
htca
I got this error:
My version is 3.6802
2017-03-09 09:54:20.583 (buienradar) Initialized version 1.1.0, author 'ffes'
2017-03-09 09:54:20.663 (buienradar) Devices created.
2017-03-09 09:54:20.663 Error: (buienradar) 'onStart' failed 'NameError':'name 'Settings' is not defined'.
2017-03-09 09:54:20.663 Error: (buienradar) ----> Line 55 in /home/pi/domoticz/plugins/domoticz-buienradar/plugin.py, function onStart
- EdwinK
No one?EdKo66 wrote:When trying to restart domoticz I get the following
ffes
Not sure which version of the beta the Settings were added, but I know in 3.6839 they were available. At the moment the latest beta is 3.6882. So please upgrade to the latest beta and that will most likely solve your issue.htca wrote:I got this error:My version is 3.6802Code: Select all
2017-03-09 09:54:20.583 (buienradar) Initialized version 1.1.0, author 'ffes' 2017-03-09 09:54:20.663 (buienradar) Devices created. 2017-03-09 09:54:20.663 Error: (buienradar) 'onStart' failed 'NameError':'name 'Settings' is not defined'. 2017-03-09 09:54:20.663 Error: (buienradar) ----> Line 55 in /home/pi/domoticz/plugins/domoticz-buienradar/plugin.py, function onStart
ffes
No sorry. Don't own a Synology so can't really help you. There has to be a way to restart a service without restarting the entire device though.EdKo66 wrote:No one?EdKo66 wrote:When trying to restart domoticz I get the following
- EdwinK
Thanks. I hope someone here will have a Synology and will answer.
