I thought I would share with you something I have knocked up to help split device,variable scripts into folders and help organise things.
I apologise if this has been done before and I'm sure there are better ways. I find this helps me without the overhead of something super rich as dzVents.
Imagine a simple file with device names and script locations
return{
deviceName = "Sensor-Front-Door",
deviceType = "door_sensor",
deviceScript = "/home/pi/domoticz/scripts/lua/device/sensor_front_door.lua",
description = [[]]
deviceName = "Boost Heating",
deviceType = "on_off_switch",
deviceScript = "/home/pi/domoticz/scripts/lua/device/boost_heating.lua",
description = [[]]
deviceName = "PIR-Hall",
deviceType = "motion_sensor",
deviceScript = "/home/pi/domoticz/scripts/lua/device/pir.lua",
description = [[]]
deviceName = "PIR-Lounge",
description = [[]]
deviceName = "PIR-Landing",
description = [[]]
deviceName = "Sensor-Garage-Door",
deviceScript = "/home/pi/domoticz/scripts/lua/device/sensor_garage_door.lua",
description = [[]]
deviceName = "sys-setpoint",
deviceType = "temp_sensor",
deviceScript = "/home/pi/domoticz/scripts/lua/device/sys_setpoint.lua",
description = [[]]
you then have one control script in the main lua directory
Master script for all devices
Script Name : script_device_control.lua
Script Path : /home/pi/domoticz/scripts/lua/
local currentPath = debug.getinfo(1).source:match("@?(.*/)")
local deviceFolderPath = currentPath ..'device/'
local commonPath = currentPath ..'common/'
local deviceArray=dofile(commonPath..'device_db.lua')
-- loop through all the changed devices
for deviceName,deviceValue in pairs(devicechanged) do
-- print ("Device based event fired on '"..deviceName.."', value '"..tostring(deviceValue).."'");
for key in pairs(deviceArray) do
if (deviceName == deviceArray[key].deviceName) then
dofile(deviceArray[key].deviceScript)
The script sets up commandArray as a global for all of the scripts that are called using dofile. This also allows you to nest dofiles.
You can do the same for variables too:
Master script for all variables
Script Name : script_variable_control.lua
local variableArray=dofile(commonPath..'variable_script_db.lua')
-- loop through all the changed variables
for variableName,variableValue in pairs(uservariablechanged) do
for key in pairs(variableArray) do
if (variableName == variableArray[key].variableName) then
dofile(variableArray[key].script)
Cheers
