Well, after a few hours, value stopped refreshing again. Even my "cron hack" doesn't help now.
I enabled debug mode, here is what I see every 15 min, when NorthQ device wakes up:
2017-03-06 23:20:49.308 Detail, Node002, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x02, 0x02, 0x84, 0x07, 0x70
2017-03-06 23:20:49.311 Detail,
2017-03-06 23:20:49.313 Info, Node002, Received Wakeup Notification from node 2
2017-03-06 23:20:49.315 Info, Node002, Node 2 has been marked as awake
2017-03-06 23:20:49.315 Detail, Node002, Queuing (WakeUp) MeterCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x32, 0x01, 0x00, 0x25, 0x0e, 0xff
2017-03-06 23:20:49.317 Detail, Node002, Queuing (WakeUp) BatteryCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x80, 0x02, 0x25, 0x0f, 0x4d
2017-03-06 23:20:49.319 Detail, Node002, Queuing (Query) Query Stage Complete (Dynamic)
2017-03-06 23:20:49.320 Detail, Node002, Notification: Notification - Node Awake
2017-03-06 23:20:49.322 Detail,
2017-03-06 23:20:49.324 Info, Node002, Sending (WakeUp) message (Callback ID=0x0e, Expected Reply=0x04) - MeterCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x32, 0x01, 0x00, 0x25, 0x0e, 0xff
2017-03-06 23:20:49.336 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-03-06 23:20:49.339 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2017-03-06 23:20:49.443 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0x0e, 0x01, 0x00, 0x0b, 0xef
2017-03-06 23:20:49.445 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x0e received (expected 0x0e)
2017-03-06 23:20:49.446 Info, Node002, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2017-03-06 23:20:49.448 Info, Node002, Node 2 has been marked as asleep
2017-03-06 23:20:49.448 Info, Node002, Node not responding - moving message to Wake-Up queue: MeterCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x32, 0x01, 0x00, 0x25, 0x0e, 0xff
2017-03-06 23:20:49.450 Info, Node002, Node not responding - moving message to Wake-Up queue: BatteryCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x80, 0x02, 0x25, 0x0f, 0x4d
2017-03-06 23:20:49.452 Info, Node002, Node not responding - moving QueryStageComplete command to Wake-Up queue
2017-03-06 23:20:49.454 Detail, Node002, Notification: Notification - Node Asleep
And at some point, a miracle happened, and I managed to see read value in debug output (difference is in red):
2017-03-06 22:50:35.458 Detail, Node002, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x02, 0x02, 0x84, 0x07, 0x70
2017-03-06 22:50:35.460 Detail,
2017-03-06 22:50:35.462 Info, Node002, Received Wakeup Notification from node 2
2017-03-06 22:50:35.463 Info, Node002, Node 2 has been marked as awake
2017-03-06 22:50:35.464 Detail, Node002, Queuing (WakeUp) MeterCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x32, 0x01, 0x00, 0x25, 0x0e, 0xff
2017-03-06 22:50:35.466 Detail, Node002, Queuing (WakeUp) BatteryCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x80, 0x02, 0x25, 0x0f, 0x4d
2017-03-06 22:50:35.467 Detail, Node002, Queuing (Query) Query Stage Complete (Dynamic)
2017-03-06 22:50:35.469 Detail, Node002, Notification: Notification - Node Awake
2017-03-06 22:50:35.470 Detail,
2017-03-06 22:50:35.472 Info, Node002, Sending (WakeUp) message (Callback ID=0x0e, Expected Reply=0x04) - MeterCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x32, 0x01, 0x00, 0x25, 0x0e, 0xff
2017-03-06 22:50:35.485 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-03-06 22:50:35.488 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2017-03-06 22:50:35.518 Detail, Node002, Received: 0x01, 0x14, 0x00, 0x04, 0x00, 0x02, 0x0e, 0x32, 0x02, 0x22, 0x64, 0x00, 0x00, 0x3d, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xac
2017-03-06 22:50:35.520 Detail,
2017-03-06 22:50:35.522 Info, Node002, Response RTT 48 Average Response RTT 48
2017-03-06 22:50:35.522 Detail, Node002, Initial read of value
2017-03-06 22:50:35.524 Info, Node002, Received Meter report from node 2: Gas=15.620cubic meters
2017-03-06 22:50:35.526 Detail, Node002, Initial read of value
2017-03-06 22:50:35.528 Detail, Node002, Notification: ValueChanged
2017-03-06 22:50:35.529 Detail, Node002, Notification: ValueChanged
2017-03-06 22:50:35.592 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0x0e, 0x01, 0x00, 0x0c, 0xe8
2017-03-06 22:50:35.596 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x0e received (expected 0x0e)
2017-03-06 22:50:35.598 Info, Node002, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2017-03-06 22:50:35.600 Info, Node002, Node 2 has been marked as asleep
2017-03-06 22:50:35.600 Info, Node002, Node not responding - moving message to Wake-Up queue: MeterCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x32, 0x01, 0x00, 0x25, 0x0e, 0xff
2017-03-06 22:50:35.602 Info, Node002, Node not responding - moving message to Wake-Up queue: BatteryCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x80, 0x02, 0x25, 0x0f, 0x4d
2017-03-06 22:50:35.604 Info, Node002, Node not responding - moving QueryStageComplete command to Wake-Up queue
2017-03-06 22:50:35.606 Detail, Node002, Notification: Notification - Node Asleep
However, I don't know how I managed to have this, and I am unable to reproduce it.
Any idea anyone?
