Update Arduino code without becoming a new node in Domoticz?
popunonkok
Post by popunonkok »
Is there a way to update the Arduino code without the attached sensors becoming new sensors in Domoticz?
My Example is that I now have a fully functional node with 2 switches (Door/Lock). However. I would like to modify the Arduino code so that I can add the function to send Battery status as well.
Is there a way? I guess the same goes for Updating a node if the MySensors Library version changes.
jeroenvanpelt
Domoticz version: 3.8153
Re: RE: Update Arduino code without becoming a new node in Domoticz?
Post by jeroenvanpelt »
popunonkok wrote:Is there a way to update the Arduino code without the attached sensors becoming new sensors in Domoticz?
If I am not mistaken, your sensor will keep it's node ID. This means your sensor in Domoticz will stay the same. It only gets a new node ID is you use the ClearEprom.ino sketch if I remember correctly. Hopefully someone can confirm this?
Sent from my Nexus 6P using Tapatalk
Domoticz latest stable - RaspberryPi 2 B - MySensors - Controlicz - Google Home - RFLink (w/MiLight)
Jimbolaya
Domoticz version: 4.11207
Re: Update Arduino code without becoming a new node in Domoticz?
Post by Jimbolaya »
Yes, the node ID is stored in the eprom. However, the eprom overwritten when a new sketch is uploaded. Include a line in the sketch to assign the node ID.
#DEFINE MY_NODE_ID 6
Jim
jeroenvanpelt
Re: RE: Re: Update Arduino code without becoming a new node in Domoticz?
Jimbolaya wrote:Yes, the node ID is stored in the eprom. However, the eprom overwritten when a new sketch is uploaded. Include a line in the sketch to assign the node ID.
Hmm, in my (anecdotal) experience, the nodes I have worked with do not get a different ID until I use the ClearEprom sketch. Just reflashing a modified sketch does not change it. Or is it the controller (Domoticz) that causes this maybe?
napo7
Post by napo7 »
I noticed that using an USBASP with arduino IDE does clear the EEPROM memory.
To keep my nodes ID, I have to dump the EEPROM before updating (via avrdude command line), flash my new program, then write back my EEPROM dump.
gohan
Post by gohan »
If you just program Arduino with standard USB interface, the node ID stays in eeprom
