My Philips Hue bridge has been added to Domoticz which runs on a Raspberry Pi. I can see the Groups, the lights and the scenes.
When I switch on a scene it works as expected, but when I switch off a scene nothing happens. When I switch a group on and off it works as expected.
How can I solve this?
Regards Jaap
Philips Hue scenes do turn on but not turn off
- Domoticz version: 4.9700
Re: Philips Hue scenes do turn on but not turn off
in the original Hue app a scene can be activated. Switching off is done by either activating another scene or by turning off all lights.
I would expect that this same approach must be done in Domoticz
Raspberry Pi3; Razberry V2; RFlink; PIco UPS HV3.0
- Target OS: -
Jaap,
I've implemented groups for on/off grouped hue bulbs. And implemented a selector switch to 'walk' through the available on/off switches from the hue bridge. The levels are with the toggle command and off for the specific group.
This is the best working way possible.
Thanks. I will try that.
- EdwinK
- Domoticz version: BETA
Can you explain hoe you've done this?stlaha2007 wrote:Jaap,
- Target OS: -
To get you started, and not having all detail at hand...
In a few words....
-Add Hue bridge
-make scene through native app
results in new devices (need to have setting allow new hardware/devices enabled)
-Create Dummy type hardware
-add new switch type selector
-tab switches/edit selector switch
-fill url lines with http://domoticzip/json.htm.... see the json-api wiki!
Etcetera....
In a few words....
-Add Hue bridge
Etcetera....
- EdwinK
thanks. Will try this out tomorrow
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
