Timer plugin?HomeAutomation wrote:Works perfect.mvzut wrote:It's just as if you are controlling a lamp: You can use LUA on/off commands (commandArray['<status device name>'] = 'On') to start/pause a player with the current playlist, and you can use the volume device as if it was a dimmer (using e.g. commandArray['<volume device name>']= 'Set Level 30').HomeAutomation wrote:How to control Sonos by LUA script
Does anybody have a example how to control the Sonos plugin with a LUA script?
Jan
As far as I know the plugin can't be used to e.g. skip to the next song or to start a particular playlist. The virtual remote doesn't work (yet).
Integreated Sonos in my WakeUp alarm.
Now, based on one time setting, I'm able to control my bedroom light (WakeUp), central heating and Sonos.
Still looking for a timer pluging however.?
Create an dummy switch and conenct it to blocky.
Define the Sonos to start playing directly and stop after x minutes.
