wildcards in lua
hmjgriffon
wildcards in lua
Post by hmjgriffon »
I've got a script for door sensors, I'd like to have one block handle all of the door sensors using wildcards since the naming convention is the same, example:
if (devicechanged['BackDoorSwitch (Sensor)'] == 'Open' and otherdevices['Security Switch'] == 'Armed') then
commandArray['SendNotification']='Security Alert! Back Door has been opened!#2'
elseif (devicechanged['BackDoorSwitch (Sensor)'] == 'Open' and otherdevices['Security Switch'] == 'Armed Home') then
can I modify this to look for all sensors named *DoorSwitch and then send an alert with the name of whatever door or is tripped?
simonrg
Domoticz version: 3.8807
Re: wildcards in lua
Post by simonrg »
hmjgriffon wrote:I've got a script for door sensors, I'd like to have one block handle all of the door sensors using wildcards since the naming convention is the same, example:
If your DoorSwitch are called, BackDoorSwitch, FrontDoorSwitch, ... etc. then this will check each device changed and if the last 10 letters are DoorSwitch (same spelling same cases) then it will do the standard logic:
tc=next(devicechanged)
v=tostring(tc)
if v:sub(-10) == 'DoorSwitch' then
   doorname = v:sub(1,-11)
   if (devicechanged[v] == 'Open' and otherdevices['Security Switch'] == 'Armed') then
       commandArray['SendNotification']='Security Alert! '..doorname..' Door has been opened!#2'
   elseif (devicechanged[v] == 'Open' and otherdevices['Security Switch'] == 'Armed Home') then
N.B. In your code example the names seem to be ...DoorSwitch (Sensor), if this is really the case then you will need to change the code to take account of this.
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
