Update a text block with status of home from a variable Topic is solved
Zweef
Post by Zweef »
Hi to you all!
I'm quite new with Domoticz. So I have a really noob question. :mrgreen:
I have made a variable with a string which represent the status of my home (Home, Sleeping, Away etc).
I want to show it in a text (or alert?) utility virtual device. How can I do that?
It seems I can't use blocks to do this. Anyone got suggestions?
Domoticz on Raspberry Pi 3 using mainly Z-Wave
Other gateways:
Fibaro HC2
Athom Homey
Zweef
Re: Update a text block with status of home from a variable
Post by Zweef »
Found it! Let me share.....
It's possible by using Domoticz API.
1 - Enable access with no protection by adding 127.0.0.* in System Setup --> Local Networks (no username/password)
2 - Restart (in my case the Raspberry Pi 3)
3 - Add in Blocky --> Messages --> Open Url: with http://
4a - Text-sensor URL:
127.0.0.1:8080/json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=TEXT
4b - Alert-sensor URL:
127.0.0.1:8080/json.htm?type=command&param=udevice&IDX&nvalue=LEVEL&svalue=TEXT
- - Explanation of nvalue Level = (0=gray, 1=green, 2=yellow, 3=orange, 4=red)
Beware not to use space-characters in TEXT. Replase with space with %20, otherwise it will not work.
Tested it with Domoticz V3.5877 on Rapberry Pi 3.
See Yah!
Other gateways:
Fibaro HC2
Athom Homey
