I just want to share my recent testing (today) with my Visonic Powermax Pro alarm system.
I've connected a Nexa WBT-912 to the internal PGM port (one to PGM to switch 1, and to GND to switch 1), and enabled the PGM in the installer menus (sends 2 seconds, Disarm = ON). The Nexa WBT-912 successfully sends ON to Domoticz via the TrxRfx433E when I disarm the alarm (I have not yet tried if it sends OFF to Domoticz when I arm the alarm, since my family is home at the moment, but I thinks it should do this).
I'm going to use this with a Proove Door sensor to automatically turn on the light when coming home (and not change lights when we are at home).
Visonic Poweraxm Pro has one built in PGM (programmable) port. You could also by a PGM-5 card to be able to send out 5 different signals (like alarm), that could be connected and send as well.
Small integration of Visonic Powermax Pro
e5rial
Re: Small integration of Visonic Powermax Pro
Just a note, this works fine. However, you have to make sure you set Arm away to OFF in PGM menu, otherwise it will never flip the PGM output (it took some time to realize this)...
